Acer AL14-31P-C8KV BIOS Request
  • justice171
    • Feb 2018
    • 110
    • South Africa
    Hello Badcaps Team,
    I am working on an Acer AL14-31P-C8KV laptop (S/N: NXKS8EA0013490A9C74500) with board number T140AN Rev 3.0A.
    I received this unit for repair, but I am uncertain if the current BIOS is correct. There are clear signs of previous work – I noticed flux residue around the BIOS chip, which suggests the BIOS may have been tampered with or reprogrammed before. Because of this, I am not confident that the backup BIN I have is the original dump or if it belongs to this exact machine.
    Could you please assist me with:
    • A clean BIOS BIN for this model, or
    • A new/repaired BIN cleaned from my dump (if possible).
    Attached is the backup. Any help would be greatly appreciated.
    Thank you in advance for your support!
    Best regards,
  • imraycooper
    • 16
    • south africa
    hello badcaps team
    i also need help with bios for t140an rev3.0a
    laptop came witho no bios chip at all but charging light is goin on
    i attach detailed images of the laptop s/n
    thank you all again
      • 22092
      Originally posted by imraycooper
      hello badcaps team
      thank you all again
      Type and post the S/N Service Tag or SNID, full name and model, motherboard model, backup etc. Don`t post pictures of the serial number...
      read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
      • imraycooper
        • 16
        • south africa
        hello badcaps team
        thank you all again
        acer aspire lite
        al14-31p-c8kv
        model no n23g1
        sn. nxks8ea00142201e4c4500
        snid-42200775645
          • 22092
          Originally posted by justice171
          Hello Badcaps Team,
          hello badcaps team
          Attached is a virgin bios with the DMI from the backup at post #1 .Just change the serial number to your own using a hex editor. The S/N is NXKS8AL00234902E3F4500
          • imraycooper
            • 16
            • south africa
            hello badcaps team
            i reprogrammed my acer using neo programmer with the above biin file
            however i still have only power led and the fan spinning continuously
            all voltages are ok
            any ideas pliz or im still stuck with my bios issue??
            • jomaseko
              • Nov 2022
              • south africa
              download another bin file
              • Wg188
                ACER Veriton Z4660G AIO bios help
                by Wg188
                I have an Acer veriton Z4660G all in one pc,
                Model: Z4660G-I5850H1 (VZ4660G_W)
                Need bios dump and schematic would save my life !
                to make a long story short I bought this all in one used
                with a broken lcd, with the objective of making a custom desktop out of it
                ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                06-17-2023, 02:20 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • Zelu
                ACER TRAVELMATE P645-S-54 N U Bios password request
                by Zelu
                Model : TMP645-S-54 NU
                S/N: NXVATEK01654900E2D3400
                MFG DATE 2015/12/02
                I had this laptop for years, came with windows 7, never bothered to check bios access until now, it is locked from the factory.
                I need access to the bios to choose another boot devices to be able to update OS.
                When trying to unlock the bios with 3 failed password attempts prompts a message with a 8 digit key (93415130) to unlock the password. Using the ones provided by biosbug does not work.
                I have seen that somebody with a similar laptop (another model of travelmate...
                10-04-2025, 06:42 PM
