Black screen. Need bios for hp 250 g10
  • Ju.salem
    • Aug 2025
    • Uae
    I put the device into hibernate mode, and after turning it back on, it didn't work. The screen remains black, and the power button blinks as if it's still in sleep mode. I removed the battery and tried turning it on with the charger only, but nothing changed. The power button just keeps blinking like it's in sleep mode repeatedly.
    I need a BIOS file.
    Hp 250 G10
    Sn: 5CD512HH34
    Motherboard: DA0PDIMB8G0
  • hoaca388
    Badcaps
    • Jan 2022
    • 12520
    I need a BIOS file.
    Hp 250 G10
    Sn: 5CD512HH34
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • Ju.salem
      • Aug 2025
      • Uae
      This is my device’s file. Can the problem be detected from the file? The power button only blinks like sleep mode and it doesn’t boot.
      • m1ch43lzm
        • Mar 2019
        • 1187
        • Peru
        Try, clean BIOS extracted from HP website with serial inserted
        HP 250G10 i3-1315U 15 8GB/512 PC (AL0C0AT)
        BIOS ver F.15
        BID 08B33
        S/N 5CD512HH34
        DMI 701000-7020FF
        With battery removed and charger plugged in, check the charge port LED, should be solid white
        • Semanza
          • Apr 2025
          • 53
          • Uganda
          hello fix for me my hp 250 g10 SN 1H84091F40
          • m1ch43lzm
            • Mar 2019
            • 1187
            • Peru
            Someone flashed a BIOS for HP 15-fd0xxx with 12th gen CPU (BID 08BB5), yours is 13th gen; different BIOS, different CPU generation, same board number
            https://partsurfer.hp.com/?searchtext=1H84091F40
            ASSY,BU IDS UMA i5-1334U HP SB6U
            Try with clean BIOS 08B33
            Fill S/N, product name, feature byte,etc. with HP BCU
            https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
            Code:
            Product name: HP 250 15.6 inch G10 Notebook PC
            Serial number: 1H84091F40
            SKU number: 968K6ET#BH5
            Build ID: 23WWSUFD601#SBH5#DBH5
            Feature byte: 3K3Y5Y6E6b7J7M7d7japawbDbhfPm9.e8
            System family: HP 200
            System board CT number: On a sticker on the motherboard CT:
            • mitchw
              HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
              by mitchw
              Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
              After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
              After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
              I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
              04-29-2025, 03:45 PM
            • Technodoc
              ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
              by Technodoc
              Asus laptop G614JZ-N3012W Rog Strix with i7
              Mainboard G634J-PMV-VGT
              6050A3441302-MB-A01
              2023-02-10
              Power button works okay....power light goes on
              Red "bottom" leds go on
              Charging led works
              Fans do not spin, capslock key does nothing, screen stays black
              I would like to program the bios again, to rule out a corrupted bios.
              However I run into a size error
              The bios chip is a Winbond 25R256JVEN
              Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
              02-24-2025, 04:46 AM
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
            • AgustinLorenzo
              [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
              by AgustinLorenzo
              Hi boys,
              This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
              Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
              Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
              After having carried out all the frequent...
              10-15-2023, 07:31 AM
            • amennone
              Acer A315-24p-r2km , black screen. Bios
              by amennone
              Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
              As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
              With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
              07-31-2025, 04:19 PM
