Thinkpad P53 'Discrete' selected in BIOS
  • tuxstevo
    • Oct 2024
    • 12
    I have a Thinkpad P53 that boots but doesn't show anything on the display since selecting 'Discrete' in the Display options in the BIOS.
    My intention was to flash the BIOS with a dump from another P53 but the good machine has a Winbond chip and the broken one a Gigadevice chip. Does anybody know if the dumps are interchangeable or, if not, does anyone have a Gigadevice dump I could use or maybe fix my dump? I'm afraid i don't have the serial number as the labels are missing and I cant get the BIOS info up on the screen.
    Thanks,
    • 20855
    Thanks,
    Post a backup of the bios chip contents, even if it is corrupt, and post the laptop serial number as well.
    Edit: . i see you posted in another thread https://www.badcaps.net/forum/troubl...57#post3687457 ,do you have it working now ?
    • tuxstevo
      • Oct 2024
      • 12
      No I haven't had any joy with this one. The other post was regarding the good machine I was hoping to use to flash this BIOS.
      I'm afraid i don't have the serial number as i can't find any labels and can't access the BIOS. I have attached the BIOS dump.
      Thanks,
        • 20855
        Thanks,
        What you`ve posted is the 1MB USB-C firmware
        • tuxstevo
          • Oct 2024
          • 12
          Thanks for pointing that out. That looked like the most likely candidate for the BIOS but I’ll have to find the right chip. If you know which one it is, that info would be much appreciated.
          Thanks,
          • tuxstevo
            • Oct 2024
            • 12
            I think this may be the right dump if you could have a look and let me know what you think?
            I have also found the label with the serial number, it is PF-2BQB4X
            Thanks,
            • lertuares
              • Jul 2025
              • 3
              Thats funny I have the same issue with 2 of these, one started after updating to the latest bios and the other came in that way, no display and resetting CMOS doesnt fix it, not sure what to do, did any dump work for you?
              • tuxstevo
                • Oct 2024
                • 12
                II haven’t got as far as flashing the BIOS yet. I was waiting to see if SMDFlea gets chance to look at my latest dump. If I have any joy, I will post back.
                  • 20855
                  Thanks,
                  Oh dear, it`s the wrong one again, this time it`s the NVIDIA vBios firmware, keep looking you`ll find it eventually.
                    • 20855
                    Post your bios backup, serial number (type as text please) and post a picture of the bios chip location
                    • tuxstevo
                      • Oct 2024
                      • 12
                      Thank you again, I’ll keep trying….
                      • tuxstevo
                        • Oct 2024
                        • 12
                        Does this one look any more promising? This was a Winbond chip by the cmos battery.
                        Thanks,
                        • tuxstevo
                          • Oct 2024
                          • 12
                          Actually I'm starting to see a pattern now. I think i am looking for a dump that is 16,384 kb so this isn't the one either
                            • 20855
                            No, it`s the thunderbolt firmware.. ,but what you posted so far will help others.
                            • tuxstevo
                              • Oct 2024
                              • 12
                              I’m afraid I’m out of ideas with this one. The P53 must store its BIOS somewhere completely different to the other P5* laptops. I’ll have to concede defeat and change the motherboard.
                              Thanks for your help 🙂
                                • 20855
                                You give up too easy it`s gotta be there, somewhere. What`s the motherboard model number, there might be a boardview that will help locate it. Have you peeled back the black plastic sheets and looked underneath
                                • tuxstevo
                                  • Oct 2024
                                  • 12
                                  Hi
                                  Yes I’ve looked under all the plastic. The number on the board is FP530 NM-C262 Rev 1.0.
                                  Thanks,
                                    • 20855
                                    Hi
                                    Thanks,
                                    The chip is at U9 in the boardview/schematic. It`s a WSON8 type chip, if you only have a SOP8 clip it will not fit. You will have to desolder it and put it in or on a WSON adapter board, use a WSON pogo adapter (less reliable) ,or solder wires between the programmer and exposed pads - traces - caps - resistors
                                    • tuxstevo
                                      • Oct 2024
                                      • 12
                                      That’s great - thanks. I would never have guessed it was that one. I’ll have a go at reading it and come back, although it might take me a couple of days as I don’t think any of the clips I have will fit.
                                      • lertuares
                                        • Jul 2025
                                        • 3
                                        omg where did you get that boardview from (also where does everyone keep getting all sorts of these views from, is there an archive hidden from me, all I find is paid probably scam sites) , could you send me that by any chance?
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • Joluvillas
                                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                        by Joluvillas
                                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                        06-18-2024, 10:35 PM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • 1g0r
                                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                        by 1g0r
                                        First, the data in brief:
                                        Manufacturer: Lenovo
                                        Model: ThinkPad L15 G3 21C3-0016GE
                                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                        IC Bios 1: MX77L25650F
                                        IC Bios 2​: MX25L25673G
                                        EC Chip: NPCX997KAABX
                                        So far I've been a silent reader, but now I need your help
                                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                        01-18-2025, 02:39 AM
                                      • MDSI
                                        HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                        by MDSI
                                        I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                        Details:
                                        Model : HP OMEN 17-an012nf
                                        Motherboard Part Number : DAG3BAMBAF0 REV : F
                                        Serial Number (S/N) : 5CD7280D51
                                        BIOS chip : Winbond W25Q64VSIQ
                                        Programmer : EZP2023+
                                        Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                        I already...
                                        07-28-2025, 07:11 AM
