Hi all notebook asus fx517zc-hn058 board da0njlmbae0 rev e video is rtx3050 need bios dump
da0njlmbae0 rev e rtx3050 bios
Hi all notebook asus fx517zc-hn058 board da0njlmbae0 rev e video is rtx3050 need bios dumpTags: None -
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting -
FX517ZCAttached Files↵
https://www.badcaps.net/donateComment
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
