MSI MS-15p3 bios, Pulse 16 AI C1V
  • Gado229
    • Aug 2023
    • 22
    • Benin
    Hello everyone, I have an MSI MS-15P3 Pulse 16 AI C1V that boots, doesn't display, and then the fan spins rapidly.
    Can you help me find a working file to flash?
    The old main BIOS file is attached.
    SN: K2411N0110648
  • peste
    • 13931
    • ROMANIA
    SN: K2411N0110648
    choose the correct model..
    https://www.msi.com/Laptop/Pulse-16-...e-16-AI-C1VFKG
    • Gado229
      • Aug 2023
      • 22
      • Benin
      Originally posted by peste
      Thanks for the quick reply, I already downloaded this and programmed the bios with the XGecu pro but the computer still won't turn on.
      • peste
        • 13931
        • ROMANIA
        if you wrote it correctly then the laptop has another problem...
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
