Lenovo S145-15IKB Bios Request
  • krsta
    • Nov 2020
    • 33
    • Croatia
    I have a Lenovo laptop :
    Lenovo Ideapad S145-15IKB
    Model Name: 81VD
    SN: PF2DRJX1
    i3 8th gen
    GS44B/GS54B/NM-C561
    REV: 1.0
    2019-05-30
    that was power cycling, white light on power led turning on and off, fan spinning on and off (the same problem dicky96 had, watch the youtube channel).
    Some voltages were present.
    I tried downloading and flashing clean bios cscn17ww.bin from post 72 from peste from thread " lenovo IdeaPad S145 bios needed
    After the flash i got all voltages except on coil PL5901 and the laptop is not power cycling anymore, the power light stays on, fan spins but i get no picture.
    Is running the DMI script necessary or does it only hold data like serial number and so?
    Thx in advance
  • Ponto da Manutenção
    • May 2024
    • 99
    • Brasil
    Here is the corrected file.
    • krsta
      • Nov 2020
      • 33
      • Croatia
      Thank you for helping.
      I flashed the bios file and the simptopms stayed the same. I only have Ch431A programmer so i cannot flash the ec chip.
      Ill buy a EC programmer , you never know when you will need it
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • grimacelord
        by grimacelord
        Hello there.
        History:
        03-15-2023, 03:29 PM
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • mkdj
        Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
        by mkdj
        Dear all,
        I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
        Here the steps I have taken to fix the laptop:
        - downloaded latest BIOS from Lenovo Website...
        10-18-2025, 03:43 AM
