need bios hp 15s-eq1017nv
    Hi i am looking BIOS for Hp laptop 15s-eq1017nv. Board is DA0P5GMB6H0
    MODEL: 0P5G
    SERIAL : 5CD1417WD5
    MODEL: 0P5G
    SERIAL : 5CD1417WD5
    post the contents of the bios chip even if it is corrupted..
      OLD BIOS
        OLD BIOS
        the bios is longer...
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..
        here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        make another copy and post again..check the length of the bios before posting..
          I have already unsoldered and read by programmer. It is 16mb. Should be more?
            16,777,216...that must be the length...see what length yours is..
              the file is zipped and inside the .bin is 16.778.752 byte
                the length of the 16MB bios must be 16,777,216...the length of your bios is 16,778,752...and I'm telling you that your bios is longer than the correct bios...what didn't you understand?
                make more copies and post a correct copy...
                  I made more copies and i post the new one. The programmer i have is TL 866 II PLUS and the ic size is 16777216 + 0xC00 Bytes as it says. The only difference was that the chip is 128D and not 128C. Please look the new file and i guess i am not doing anything wrong with reading...
                    the bios is just as long...
                    bios extracted from the HP website update for HP Laptop 15s-eq1017nv (312J4EA), the laptop has two bios variants, yours is 08707
                    DMI 0 - 10FF
                    KEY WIN 8000 - 803F
                      Did you choose an OTP chip.
                        DMI 0 - 10FF
                        KEY WIN 8000 - 803F
                        thank you for your help! i appreciate it! Maybe i have another issue. Still starts with black screen.. I give up.
