need bios hp 15s-eq1017nv
  • memoslar
    • Apr 2015
    • 122
    • Greece
    Hi i am looking BIOS for Hp laptop 15s-eq1017nv. Board is DA0P5GMB6H0
    MODEL: 0P5G
    SERIAL : 5CD1417WD5
  • peste
    • Dec 2016
    • 13421
    • ROMANIA
    MODEL: 0P5G
    SERIAL : 5CD1417WD5
    post the contents of the bios chip even if it is corrupted..
    • memoslar
      • Apr 2015
      • 122
      • Greece
      OLD BIOS
      • peste
        • Dec 2016
        • 13421
        • ROMANIA
        OLD BIOS
        the bios is longer...
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..​
        here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        make another copy and post again..check the length of the bios before posting..
        • memoslar
          • Apr 2015
          • 122
          • Greece
          I have already unsoldered and read by programmer. It is 16mb. Should be more?
          • peste
            • Dec 2016
            • 13421
            • ROMANIA
            16,777,216...that must be the length...see what length yours is..
            • memoslar
              • Apr 2015
              • 122
              • Greece
              the file is zipped and inside the .bin is 16.778.752 byte
              • peste
                • Dec 2016
                • 13421
                • ROMANIA
                the length of the 16MB bios must be 16,777,216...the length of your bios is 16,778,752...and I'm telling you that your bios is longer than the correct bios...what didn't you understand?
                make more copies and post a correct copy...​
                • memoslar
                  • Apr 2015
                  • 122
                  • Greece
                  I made more copies and i post the new one. The programmer i have is TL 866 II PLUS and the ic size is 16777216 + 0xC00 Bytes as it says. The only difference was that the chip is 128D and not 128C. Please look the new file and i guess i am not doing anything wrong with reading...
                  • peste
                    • Dec 2016
                    • 13421
                    • ROMANIA
                    the bios is just as long...
                    bios extracted from the HP website update for HP Laptop 15s-eq1017nv (312J4EA), the laptop has two bios variants, yours is 08707
                    DMI 0 - 10FF
                    KEY WIN 8000 - 803F
                      • 21679
                      Did you choose an OTP chip.
                      • memoslar
                        • Apr 2015
                        • 122
                        • Greece
                        DMI 0 - 10FF
                        KEY WIN 8000 - 803F
                        thank you for your help! i appreciate it! Maybe i have another issue. Still starts with black screen.. I give up.
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • Friend33
                          Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
                          by Friend33
                          I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
                          06-16-2024, 03:13 PM
