Asus Zephyrus GA402XV Bios
  • Mouseketier
    • May 2020
    I have a Asus GA402XV board number ga402xi-pmv-vgt. Someone threw it in the trash. I have worked down to the issues being the bios is corrupt. I have successfully flashed the bios downloaded from asus site and machine boots. How ever the serial number is missing and windows key. I have uploaded both the old bios and one i flashed. Could someone help me correct this or point me in the direction of how to myself.
    Asus GA402xv
    Board number GA402XI-PMV-VGT
    Serial Number R7NRKD01771628A
  • hoaca388
    Badcaps
    • Jan 2022
    • 12392
    Asus GA402xv
    GA402XV
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • Ngo Duy Trung
      asus rog zephyrus g14 ga402xv bios
      by Ngo Duy Trung
      Hello everyone I stupidly updated the bios on my Asus and it got corrupted.
      Can anyone edit the hex bios file for my device? My bios chip W25Q16JVSNIQ Winbond has a capacity of 16Mb but the bios file I downloaded on the Asus homepage is 32Mb. Can anyone help me edit the hex and adjust it for me so I can flash the bios, please?
      Thank you so much😥
      This is the original bios file from Asus website and motherboard number:
      model number: GA402XI-PMV-VGT
      6050A3447304-MB-A01​...
      06-27-2024, 08:56 AM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • mkdj
      What should I do after having flashed a BIOS?
      by mkdj
      Dear all,
      I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
      Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
      09-09-2025, 09:45 AM
    • skdsp
      Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
      by skdsp
      I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
      Attached is the photo.
      Thank you!
      09-27-2025, 09:05 PM
