There is an image here https://***********/attachments/clss-bin-zip.255396/ but they charge crazy prices for registering. Can someone find a BIOS for this Razer Blade? Thanks
					RZ09-03519 need a BIOS Image.
 Every donation made will go towards server fees and maintenance costs.Comment
 Here's my EC Firmware dump. I suspect this is the issue as well as no HID devices and USB doesn't work. Mass Storage and USB NICs do work though.Attached FilesComment
 TryAttached Files↵
 https://www.badcaps.net/donateComment
			by AwdevS/N is BY2011A72401766
 Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
 MB Model is: DA530-MB
 Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....-
							Channel: BIOS Requests ONLY!
			by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
 So, I'm looking for a BIOS dump for this machine - a 16MB one....-
			by Focus2005Hello everyone.
 I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...-
			by DynaxSCHi,
 Usually on ASUS boards it worked...-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
 Operating system and OS version.If...-
- Loading...
