There is an image here https://***********/attachments/clss-bin-zip.255396/ but they charge crazy prices for registering. Can someone find a BIOS for this Razer Blade? Thanks
RZ09-03519 need a BIOS Image.
Every donation made will go towards server fees and maintenance costs.Comment
Here's my EC Firmware dump. I suspect this is the issue as well as no HID devices and USB doesn't work. Mass Storage and USB NICs do work though.Attached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
Channel: BIOS Requests ONLY!
by Focus2005Hello everyone.
I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by grimacelordHi folks,
I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
Service tag number for this model is: "JYDWYW1".
Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
I have tried:
- Simply extracting with 7zip
- PFSExtractor
- Using "/writeromfile, /writehdrfile, and /writehexfile" commands
- Check Temp folder
- Loading...
