RZ09-03519 need a BIOS Image.
  • Awdev
    • Feb 2025
    • 10
    • US
    There is an image here https://***********/attachments/clss-bin-zip.255396/ but they charge crazy prices for registering. Can someone find a BIOS for this Razer Blade? Thanks
  • Awdev
    • Feb 2025
    • 10
    • US
    Here is my current Dump
    • peste
      • Dec 2016
      • 12666
      • ROMANIA
      post S/N, full name and model, motherboard model,etc.
      • Awdev
        • Feb 2025
        • 10
        • US
        Here's my EC Firmware dump. I suspect this is the issue as well as no HID devices and USB doesn't work. Mass Storage and USB NICs do work though.
        • Awdev
          • Feb 2025
          • 10
          • US
          S/N is 622102M10001490
          Full name: RZ09-0319E11-R3U1 Razer Blade 15” (2020) | RZ09-03519
          MB Model is: OL510-MB
          • hoaca388
            Badcaps
            • Jan 2022
            • 11653
            Try
            • Awdev
              • Feb 2025
              • 10
              • US
              Originally posted by hoaca388
              Try
              Works, but I think the EC Firmware is bad.
              I get version 1.02 for bios and EC is 1.0
              Do you have a EC Firmware?
              • Awdev
                • Feb 2025
                • 10
                • US
                Here's system info
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11653
                  Here's system info
                  I don't have it and there is no bios for this model on the Raze website.
                  • Awdev
                    • Feb 2025
                    • 10
                    • US
                    It appears to be a separate image stored on another EEPROM. The dump is above if you want to look at it
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11653
                      I know but can't find Ec on Raze homepage.
                      • Awdev
                        • Feb 2025
                        • 10
                        • US
                        In contact with razer now, if i get an image i will post here
                        • Awdev
                          • Feb 2025
                          • 10
                          • US
                          Does the dump above look corrupted to you?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11653
                            yES
                            • Awdev
                              • Feb 2025
                              • 10
                              • US
                              Thank You!
                              • vinaypundith
                                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                by vinaypundith
                                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                08-03-2024, 12:32 PM
                              • Focus2005
                                HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                by Focus2005
                                Hello everyone.
                                I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                05-01-2025, 05:41 AM
                              • DynaxSC
                                by DynaxSC
                                06-14-2024, 03:49 PM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • grimacelord
                                Latitude E6530 - Trouble Extracting BIOS Image From EXE
                                by grimacelord
                                Hi folks,
                                I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                                Service tag number for this model is: "JYDWYW1".
                                Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                                I have tried:
                                • Simply extracting with 7zip
                                • PFSExtractor
                                • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                                • Check Temp folder
                                10-26-2023, 08:15 AM
