Asus FA706N DA0NJXMBAB0 REV B bios
  • erickirchey
    Justme
    • Aug 2022
    • 24
    Asus FA706N
    DA0NJXMBAB0 REV B
    Serial S1NRCX011003015
    Need Bios Password TIA
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Originally posted by erickirchey
    Asus FA706N
    DA0NJXMBAB0 REV B
    What you posted is Nvidia firmware, not bios.
    • erickirchey
      Justme
      • Aug 2022
      • 24
      The normal location from what I’m seeing on other revisions for the bios chip is in the bottom middle of the board however it’s not populated here on the board the only other chip I see that resembles a bios chip is a larger winbond chip 25r256jweq I’ve attached a photo of the board if anyone could help me locate the proper chip to read.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        That is it.
        • erickirchey
          Justme
          • Aug 2022
          • 24
          I've pulled that chip here is the dump
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            This chip is 32MB. See how many MB you can get.
            • erickirchey
              Justme
              • Aug 2022
              • 24
              this is with asprogrammer let me know if this works
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                Password : $197275$
                • erickirchey
                  Justme
                  • Aug 2022
                  • 24
                  That worked thank you!
                  • erickirchey
                    Justme
                    • Aug 2022
                    • 24
                    Here’s a clean bios file for this model if anyone needs
                    • erickirchey
                      Justme
                      • Aug 2022
                      • 24
                      The password worked however laptop boots to ez flash and wont go past i tried bios update via ez flash but it just causes pc to not post after using ez flash.
                      I flashed the clean bios bin i posted above and laptop boots and installs windows however will not do windows updates after doing some checking <NULL> FA706NF is in the model in device manager under computer tab I belelive the NULL string is what is causing the system to not allow windows updates can someone assist me in editing the BIOS to remove the NULL String ATTACHED is my back up BIOS and the Clean Bios file
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        From home page Asus
                        • BMCappelletti
                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                          by BMCappelletti
                          Long story short:
                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                          - gave the computer to his son a couple years later
                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                          (seems like the story was not that short)
                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                          01-08-2025, 07:27 PM
                        • DynaxSC
                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                          by DynaxSC
                          Hi
                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                          08-04-2025, 12:20 PM
                          by SMDFlea
                          Bad...
                          09-02-2021, 04:40 PM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • JoWed
                          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                          by JoWed
                          Hello Community,
                          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                          07-01-2025, 09:32 AM
