BIOS needed for DAG37AMB8C0
  • questore
    • Dec 2015
    • 555
    • csongrád
    Hi Everyone,
    I have a missing BIOS IC in a DAG37AMB8C0 REV C board so I need a BIOS to upload to the new IC
    ProdID: G37SKUS#ABA
    S/N: 5CD6123ZHV
    Can you post a WORKING one?
    • 21669
    The serial number is invalid at HP support, check it again.
    • questore
      • Dec 2015
      • 555
      • csongrád
      I donr know what to say:
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        This is a fake reprinted serial number and of course it is not in HP support.
        • questore
          • Dec 2015
          • 555
          • csongrád
          Maybe its an aftermarket base cover. I'll look for fell off stickers maybe I find one inside.
          • questore
            • Dec 2015
            • 555
            • csongrád
            Found one sticker with the followings:
            CT: PG374028J9Z02H
            21G37MB0040 VER: C3A**
            LAN: DC4A3EF3147D
            • hoaca388
              Badcaps
              • Jan 2022
              • 12268
              CT: PG374028J9Z02H
              LAN: DC4A3EF3147D
              These things don't help at all.
              • questore
                • Dec 2015
                • 555
                • csongrád
                Then i think i have to try to flash it with a DAG37AMB8D0 BIOS
                  • 21669
                  What part number is the CPU, such as SR32Q
                  • questore
                    • Dec 2015
                    • 555
                    • csongrád
                    End OF THE ID ON the CPU is SR2FP
                    • questore
                      • Dec 2015
                      • 555
                      • csongrád
                      I have found a BIOS that makes the laptop turn on for 1-2 second then shuts of. (attached BIOS+EC)
                      I have read on forums that this could be because i dont have a genuine charger for this modell, only Lab Power Supply.
                      • peste
                        • 13421
                        • ROMANIA
                        try post #3..0820D...
                        https://www.badcaps.net/forum/troubl...ighlight=0820d
                        • questore
                          • Dec 2015
                          • 555
                          • csongrád
                          Originally posted by peste
                          NO solution
                          - With: 0820D.bin - Turns on and then off after 2 seconds
                          - With: 08209.bin - Turns on and draws around 0,617 Miliamps and caps lock flashes 5 long-3 short (I think it means BIOS is not reached within a timelimit, but correct me if I'm wrong)
                          - With: 08217.bin - Turns on and stays for 6 seconds then turns off and starts over forever loop waited for minutes (drawing 0.028 Miliamp durring turnon)
                            • 21669
                            NO solution
                            SR2FP Intel Core i5-6300HQ​ = Skylake H
                            These bios are for Skylake H
                            BID0820D SKYLAKE H
                            BID0825F SKYLAKE H
                            BID08294 SKYLAKE H
                            https://www.badcaps.net/forum/troubl...0-rev-d-e-bios
                            Flash the matching EC as well. The EC files are all different.
                            • questore
                              • Dec 2015
                              • 555
                              • csongrád
                              [QUOTE=SMDFlea;n3606426]
                              SR2FP Intel Core i5-6300HQ = Skylake H
                              BID0820D SKYLAKE H
                              BID0825F SKYLAKE H
                              BID08294 SKYLAKE H
                              (BID0820D) Flashed with the matching EC as well. Still turns on for 2 seconds and then shutdown.
                              Should i try different? (I dont found EC for other versions)
                                • 21669
                                [QUOTE=questore;n3606447]
                                BID0820D SKYLAKE H
                                BID0825F SKYLAKE H
                                BID08294 SKYLAKE H
                                All the EC versions are at post 3 in that thread
                                • questore
                                  • Dec 2015
                                  • 555
                                  • csongrád
                                  [QUOTE=SMDFlea;n3606496]
                                  Sorry I have passed that I dont know how.
                                  • questore
                                    • Dec 2015
                                    • 555
                                    • csongrád
                                    Same results with all the 3 EC+BIOS pair as before.
                                    Also I have got an HP power adapter 230W and I have borrowed an adapter to try 7.4x5.0mm -> 4.5x3.0mm center pin). Its lowering the AD_ID value so after adapter AD_ID is only 0.6V (thinks its a 65w charger) and the laptop not reacting to power button (obviously). So I know that EC is working at least that part.
                                    Try to get a genuine charger and get back to you.
                                    • questore
                                      • Dec 2015
                                      • 555
                                      • csongrád
                                      Now that I have a genuine charger...
                                      Tryed all version with EC flashed and correct BIOS and none of them even reacts to power button.
