LENOVO FLEX 5 14ITL05 BIOS REQUEST
  • mikrotik
    • Mar 2025
    • 5
    Greetings all,
    I have a laptop that no longer functions after a possible bad windows update - after update it no longer turned on. Laptop has 12.3v running, bios chip has 3.3v running - just doesn't power up nor does power button work. Screen stays black. Posting full rom with ME & BIOS region.
    BOARD CODE: LC56-14T
    Lenovo Model: 82HS000WUS
  • hoaca388
    Badcaps
    • Jan 2022
    • 11738
    Originally posted by mikrotik
    Greetings all,
    Serial number ?
    • mikrotik
      • Mar 2025
      • 5
      Serial should be in the bios. The dump is from the bad file.
      Either way it is: R9107Q9K
      • hoaca388
        Badcaps
        • Jan 2022
        • 11738
        You MUST:
        • Read BIOS guides, methods, resources and tools
        • Try the method at BIOS guides, methods, resources and tools before requesting help
        • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
        • Use search function in case someone already answered your request
        • Post under a related thread if it exists
        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • Name your thread with make, full model numbers and request
        • Provide a BIOS/EC dump if possible
        • Attach files directly to your post instead of linking to external websites
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such term
        • mikrotik
          • Mar 2025
          • 5
          I have read the guides, know how to work the tools! I'm currently flashing a new file for which i replaced the BIOS region with the official Lenovo bios FXCN49WW region file, then replaced the non-empty padding. Let's see if it works....
          The serial again is R9107Q9K
          Lenovo Model: 82HS000WUS​
          • volinakis
            • Jan 2021
            • 2733
            • N/A
            It will never work if you replace only ME Region, you also have to do a clean_ME. Try this one.
            Next time read more carefully the rules of this forum, serial no. is mandatory to identify your machine and to extract right files from updates. Also, before opening a new thread use "Search" function of this forum to see if there is already a thread for your machine ... all of this are in forum rules you pretend to read ...
