Inspiron 15 3530 bios
  • santoslao
    • Apr 2017
    • 140
    • BZ
    #41
    Originally posted by danito
    try
    Thank you for the feedback! I managed to solve it by downgrading to an initial version of bios 1.15.0, it just doesn't have this function in this version.
      • 22427
      After some googling i found it can be turned on /off provisioned/unprovisioned with dell command configure and PowerShell Provider.
      Dell Command | Configure Version 4.x Command Line Interface Reference Guide
      https://www.dell.com/support/manuals...1b3&lang=en-us
      To enable and provision ABI (Advanced BIOS Interface) on Dell systems, you typically use the Dell Command suite of utilities, such as Dell Command | Configure or Dell Command | PowerShell Provider, or configure the setting directly in the BIOS Setup.
      The exact steps and interface options may vary depending on your specific Dell model and the version of the management tools or BIOS
      Method 1: Using Dell Command | PowerShell Provider
      The Dell Command | PowerShell Provider (DCPP) is a module that allows you to manage BIOS settings from within PowerShell.
      Install the DCPP module from the Dell support site.
      Open PowerShell as an administrator.
      Navigate to the DellSmbios provider namespace:
      #powershell command# cd DellSmbios
      View the current state of ABI and provisioning
      #powershell command# Get-Item -Path DellSmbios:\Security\ABIState
      #powershell command# Get-Item -Path DellSmbios:\Security\ABIProvState
      Enable ABI state (if not already enabled)
      #powershell command# Set-Item -Path DellSmbios:\Security\ABIState -Value Enabled
      Provision ABI by setting ABIProvState to a desired value (e.g., Enabled for full access, ReadOnly, or DisabledLegacyInterface)
      #powershell command# Set-Item -Path DellSmbios:\Security\ABIProvState -Value Enabled
      Note: If a BIOS password is set, you must provide it using the -Password parameter with the Set-Item command.
      Method 2: Using Dell Command | Configure (CLI)
      Dell Command | Configure is another utility that allows command-line interface (CLI) management of BIOS settings.
      Install Dell Command | Configure from the Dell support site.
      Open Command Prompt as an administrator.
      Use the cctk command to enable and provision ABI. The specific option name is --ABIState and --ABIProvState.
      #bash command# cctk --ABIState=Enabled
      #bash command# cctk --ABIProvState=Enabled
      Note: You might need to navigate to the installation directory, typically C:\Program Files\Dell\Command Configure\X86_64 (or X86).
      Method 3: Via BIOS Setup Utility (F2 Menu)
      You can also enable this setting manually in the BIOS setup interface on individual machines.
      Restart your Dell computer.
      When the Dell logo appears, press the F2 key immediately to enter the BIOS setup program.
      Navigate to the Security section (or a similar location, path may vary by model).
      Look for options like "ABI State" and "ABI Provisioning State" (or similar terminology).
      Enable the settings as required.
      Save your changes and exit the BIOS setup. The computer will restart.
      For more information, refer to the official Dell Command documentation for your specific system model on the Dell Support website.
      • santoslao
        • Apr 2017
        • 140
        • BZ
        #43
        Originally posted by SMDFlea
        After some googling i found it can be turned on /off provisioned/unprovisioned with dell command configure and PowerShell Provider.....
        Another machine like this arrived with the same problem, I tried to do it using these commands and programs from Dell, and I can say that it doesn't work! I believe that the commands are just to enable Legacy, as to disable it, none of them work, just placing an old Dump clearME, as I mentioned above.
        • sualaptop.com
          • Oct 2025
          • 20
          • VIỆT NAM
          #44
          Dell inspiron 15-3530 i7-13 bios not working need good bios thanks S/T: 15JR9X3 EX: 2512298487
            SMDFlea commented
            Editing a comment
            post moved from vostro 3530 topic to inspiron
        • 3pka
          • Aug 2024
          • 48
          • Mongolia
          #45
          Dell Inspiron 15 3530 IDH5A LA-M366P
          No post only black screen with caps lock light.
          Laptop doesn't have stickers can not find service tag sorry.
          • 3pka
            • Aug 2024
            • 48
            • Mongolia
            #46
            Found on box ST: 3XH4Y64
            • LBTT1121
              • Nov 2024
              • 1273
              • Việt Nam
              #47
              try and feedback
              • 3pka
                • Aug 2024
                • 48
                • Mongolia
                #48
                Originally posted by LBTT1121
                try and feedback
                Thank you for your try. Now Laptop seems boot looping 3 sec caps lock led on then rebooting and fan too.
                • Elmoreno12
                  • Sep 2017
                  • 4
                  • centroAmerica
                  #49
                  Service Tag: 3X7MTW3
                  Main: IDH50 - M367P
                  REV: 1.0 ( A00 )
                  Please fix bios
                  • 3pka
                    • Aug 2024
                    • 48
                    • Mongolia
                    #50
                    try and feedback
                    Hi laptop now drawing 14W-21W but no post. Seems like always doing 1st slow boot.
                      • 22427
                      Main: IDH50 - M367P
                      REV: 1.0 ( A00 )
                      Please fix bios
                      can you explain what the problem is like no boot, caps lock flashing etc.
                      • Elmoreno12
                        • Sep 2017
                        • 4
                        • centroAmerica
                        #52
                        not power on, and another bios stuck on logo dell
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • zlr8r
                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                          by zlr8r
                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                          cheers
                          Dell Inspiron 17 (7786) Laptop
                          Service Tag: 5J0NHT2
                          Bios: 1.9.0
                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                          Attached;
                          1. My saved bios using a programmer
                          2. Dells Bios updater .exe (v1.16)
                          3. Dells Bios recovery file
                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                          5. Image of ME...
                          12-18-2023, 03:08 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
