Inspiron 15 3530 bios
  • santoslao
    • Apr 2017
    • 166
    • BZ
    #41
    Originally posted by danito
    try
    Thank you for the feedback! I managed to solve it by downgrading to an initial version of bios 1.15.0, it just doesn't have this function in this version.
      • 24616
      After some googling i found it can be turned on /off provisioned/unprovisioned with dell command configure and PowerShell Provider.
      Dell Command | Configure Version 4.x Command Line Interface Reference Guide
      https://www.dell.com/support/manuals...1b3&lang=en-us
      To enable and provision ABI (Advanced BIOS Interface) on Dell systems, you typically use the Dell Command suite of utilities, such as Dell Command | Configure or Dell Command | PowerShell Provider, or configure the setting directly in the BIOS Setup.
      The exact steps and interface options may vary depending on your specific Dell model and the version of the management tools or BIOS
      Method 1: Using Dell Command | PowerShell Provider
      The Dell Command | PowerShell Provider (DCPP) is a module that allows you to manage BIOS settings from within PowerShell.
      Install the DCPP module from the Dell support site.
      Open PowerShell as an administrator.
      Navigate to the DellSmbios provider namespace:
      #powershell command# cd DellSmbios
      View the current state of ABI and provisioning
      #powershell command# Get-Item -Path DellSmbios:\Security\ABIState
      #powershell command# Get-Item -Path DellSmbios:\Security\ABIProvState
      Enable ABI state (if not already enabled)
      #powershell command# Set-Item -Path DellSmbios:\Security\ABIState -Value Enabled
      Provision ABI by setting ABIProvState to a desired value (e.g., Enabled for full access, ReadOnly, or DisabledLegacyInterface)
      #powershell command# Set-Item -Path DellSmbios:\Security\ABIProvState -Value Enabled
      Note: If a BIOS password is set, you must provide it using the -Password parameter with the Set-Item command.
      Method 2: Using Dell Command | Configure (CLI)
      Dell Command | Configure is another utility that allows command-line interface (CLI) management of BIOS settings.
      Install Dell Command | Configure from the Dell support site.
      Open Command Prompt as an administrator.
      Use the cctk command to enable and provision ABI. The specific option name is --ABIState and --ABIProvState.
      #bash command# cctk --ABIState=Enabled
      #bash command# cctk --ABIProvState=Enabled
      Note: You might need to navigate to the installation directory, typically C:\Program Files\Dell\Command Configure\X86_64 (or X86).
      Method 3: Via BIOS Setup Utility (F2 Menu)
      You can also enable this setting manually in the BIOS setup interface on individual machines.
      Restart your Dell computer.
      When the Dell logo appears, press the F2 key immediately to enter the BIOS setup program.
      Navigate to the Security section (or a similar location, path may vary by model).
      Look for options like "ABI State" and "ABI Provisioning State" (or similar terminology).
      Enable the settings as required.
      Save your changes and exit the BIOS setup. The computer will restart.
      For more information, refer to the official Dell Command documentation for your specific system model on the Dell Support website.
      • santoslao
        • Apr 2017
        • 166
        • BZ
        #43
        Originally posted by SMDFlea
        After some googling i found it can be turned on /off provisioned/unprovisioned with dell command configure and PowerShell Provider.....
        Another machine like this arrived with the same problem, I tried to do it using these commands and programs from Dell, and I can say that it doesn't work! I believe that the commands are just to enable Legacy, as to disable it, none of them work, just placing an old Dump clearME, as I mentioned above.
        • sualaptop.com
          • Oct 2025
          • 23
          • VIỆT NAM
          #44
          Dell inspiron 15-3530 i7-13 bios not working need good bios thanks S/T: 15JR9X3 EX: 2512298487
            SMDFlea commented
            Editing a comment
            post moved from vostro 3530 topic to inspiron
        • 3pka
          • Aug 2024
          • 58
          • Mongolia
          #45
          Dell Inspiron 15 3530 IDH5A LA-M366P
          No post only black screen with caps lock light.
          Laptop doesn't have stickers can not find service tag sorry.
          • 3pka
            • Aug 2024
            • 58
            • Mongolia
            #46
            Found on box ST: 3XH4Y64
            • LBTT1121
              • Nov 2024
              • 2177
              • Việt Nam
              #47
              try and feedback
              • 3pka
                • Aug 2024
                • 58
                • Mongolia
                #48
                Originally posted by LBTT1121
                try and feedback
                Thank you for your try. Now Laptop seems boot looping 3 sec caps lock led on then rebooting and fan too.
                • Elmoreno12
                  • Sep 2017
                  • 8
                  • centroAmerica
                  #49
                  Service Tag: 3X7MTW3
                  Main: IDH50 - M367P
                  REV: 1.0 ( A00 )
                  Please fix bios
                  • 3pka
                    • Aug 2024
                    • 58
                    • Mongolia
                    #50
                    try and feedback
                    Hi laptop now drawing 14W-21W but no post. Seems like always doing 1st slow boot.
                      • 24616
                      Main: IDH50 - M367P
                      REV: 1.0 ( A00 )
                      Please fix bios
                      can you explain what the problem is like no boot, caps lock flashing etc.
                      • Elmoreno12
                        • Sep 2017
                        • 8
                        • centroAmerica
                        #52
                        not power on, and another bios stuck on logo dell
                        • Ali milan
                          • Aug 2024
                          • 12
                          • Italy
                          #53
                          hi everyone
                          i have dell inspiron 3530 la-m366p suddenly start to bug , blue screen ramdomly and heats up with fan spining , this happen after windows bios update .
                          i have read the bios file and need to downgrade the bios to an old version , so i can repair the laptop and update the bios manually without issue .
                          here the file joined
                          ST: DY001Z3
                          • LBTT1121
                            • Nov 2024
                            • 2177
                            • Việt Nam
                            #54
                            Originally posted by Ali milan
                            hi everyone
                            ST: DY001Z3
                            try and feedback
                            • Ali milan
                              • Aug 2024
                              • 12
                              • Italy
                              #55
                              what bios version have you used please ?
                              thanks but you just make clean me region , and i should downgrade the bios version to an older bios , you keep the corrupted version 1.24.1
                              please i need an old version + clean me
                              thank you very much
                                SMDFlea commented
                                Editing a comment
                                Thread merged with existing inspiron 3530 topic.
                            • primolipe
                              • Oct 2014
                              • 6
                              • Brazil
                              #56
                              Hi, my laptop turns on but doesn't display an image. Could someone help me repair my BIOS?
                              Inspiron 15 3530
                              IDH50 LA-M368P Rev1.0(A00)
                              Service Tag: 249X134
                              • LBTT1121
                                • Nov 2024
                                • 2177
                                • Việt Nam
                                #57
                                Inspiron 15 3530
                                try and feedback
                                • rewanco
                                  • Nov 2015
                                  • 28
                                  • syria
                                  #58
                                  VOSTRO 3530
                                  LA-M366P
                                  ST:705H854
                                    • 24616
                                    Originally posted by rewanco
                                    VOSTRO 3530
                                    LA-M366P
                                    ST:705H854
                                    Please post your request in the VOSTRO 3530 topic - https://www.badcaps.net/forum/troubl...vostro-15-3530
                                    • rewanco
                                      • Nov 2015
                                      • 28
                                      • syria
                                      #60
                                      IDH50 LA-M366P
                                      DELL VOSTRO
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Trademark
                                        Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                        by Trademark
                                        I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                        This is NOT a BIOS password removal request.
                                        I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                        Laptop Information
                                        • Model: Acer Predator Triton 16 PT16-51-99GL
                                        • Motherboard: DA0ZQDMB8AE Rev. E
                                        • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                        • Secondary
                                        07-22-2026, 08:57 AM
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        11-14-2025, 04:04 PM
                                      • TopPop
                                        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                        by TopPop
                                        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                        12-14-2025, 09:40 PM
                                      • hikesync
                                        Dell Inspiron 24 5430 all-in-one bios
                                        by hikesync
                                        Sup friends, i look everywhere to find a bios for this all-in-one motherboard, but i didnt find.
                                        So theres a chance to fix the original bios? I will send the .RCV file from the official website
                                        Model: Dell Inspiron 24 5430 all-in-one
                                        ST: 4XCWX4
                                        Motherboard: 232017-1 8C9V8$HA...
                                        01-23-2026, 09:01 AM
