Inspiron 15 3530 bios
not working
please help me to repair my biosComment
try and feedbackAttached FilesComment
Hi guys I need to disable Legacy Manageability Interface Access on Dell Inspiron 3530 Service Tag FXB8GB4. The laptop is coming on there is no password but when you go bios settings and try to change settings on legacy manageability options its greyed out. I have tried to new bios files and its still not allowing to change those options. So far I have done clean me and also replaced bios region and still same I even tried other files from this forum but still same. I have uploaded the main bios and photo of the option. Help to enable options to change bios settings for Legacy Manageability, ThanksComment
try and feedbackHi guys I need to disable Legacy Manageability Interface Access on Dell Inspiron 3530 Service Tag FXB8GB4. The laptop is coming on there is no password but when you go bios settings and try to change settings on legacy manageability options its greyed out. I have tried to new bios files and its still not allowing to change those options. So far I have done clean me and also replaced bios region and still same I even tried other files from this forum but still same. I have uploaded the main bios and photo of the option. Help to enable options to change bios settings for Legacy Manageability, ThanksComment
is secure boot enabledHi guys I need to disable Legacy Manageability Interface Access on Dell Inspiron 3530 Service Tag FXB8GB4. The laptop is coming on there is no password but when you go bios settings and try to change settings on legacy manageability options its greyed out. I have tried to new bios files and its still not allowing to change those options. So far I have done clean me and also replaced bios region and still same I even tried other files from this forum but still same. I have uploaded the main bios and photo of the option. Help to enable options to change bios settings for Legacy Manageability, ThanksComment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by sahamipoorhi...
i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
i updated to latest version and try other version but not working!
service tag: HCQ3JW2
i need your kind....-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
