Samsung NP850xbc fault bios
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Hi folks,I have problems unzipping the file I downloaded to repair the BIOS of this notebook just nothing appears when I open only one file with 571kb 7zip or winrar
    leave you the original file and the one I managed to download from the internet, the equipment turns on randomly does not recognize the NVMe and when I bot with a pendrive after 4s the installer load is crossed
    model NP850XBC-XG1BR
    sn: 096Q9QANA00250B
    I hope you can help me solve this dilemma
    • 20391
    sn: 096Q9QANA00250B
    You can extract the update with find_gz software https://www.badcaps.net/forum/troubl...update?t=88206
    • Ponto da Manutenção
      • May 2024
      • 70
      • Brasil
      sn: 096Q9QANA00250B
      Check if it solves your problem...
      • noname2024
        • Aug 2024
        • 198
        • CỎ MỸ XỊN
        sn: 096Q9QANA00250B
        [850XBC] Odyssey2-15 BIOS/MICOM (P08AHL)
        NP850XBC-EXP, NT850XBC-CSM
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          with this one here he does not generate any kind of image, In the same way I thank you for your intention to help you are welcome
          • the Benninger
            • Nov 2022
            • 189
            • venezulan
            thanks noname2024 I have no problems when it comes to editing, but just in case you know the address of the DMI
              • 20391
              Hex search: 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
              Text search: BSA_
              • the Benninger
                • Nov 2022
                • 189
                • venezulan
                Happy week to all, I am pleased to announce that this computer was successfully repaired thanks to the collaboration of SMDFlea and noname2024 my best thanks
                • the Benninger
                  • Nov 2022
                  • 189
                  • venezulan
                  I have an update regarding this nobook, it does not initialize the video with a memory amount greater than 8gb, I initially tried to put 2x16gb and it does not start the video, I came back with the original memory, everything works correctly, I tried with a single 16gb memory, nothing, I tried 8+16/8+8/16+8 and it does not start the video, the processor only gets a little hot and the fans spin nothing else.
                  I tested with three different 8gb memory sticks and tested them again on my notebook. I also checked to see if any contacts were dirty or bent.
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                  • maanee11
                    Help to get Lenovo BIOS bin file for Thinkpad T560
                    by maanee11
                    Hello Everyone,
                    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                    05-15-2022, 11:59 AM
                  • Sebastian Codrean
                    BIOS file for ASUS F542UN laptop
                    by Sebastian Codrean
                    Hello to all of you! I need help with a BIOS file.
                    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                    02-20-2025, 10:25 AM
                  • Fr33man
                    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                    by Fr33man
                    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                    *Novo button power on
                    *Disconnected internal battery...
                    09-23-2024, 01:16 PM
                  • Kazik
                    Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
                    by Kazik
                    I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
                    I'm thinking that the NO POWER...
                    10-20-2022, 05:38 PM
