ASUS ROG STRIX G512LW-ES76 BIOS
  • pete18064
    • Jan 2025
    • 12
    MB : G532LWS R1.3
    S/N : L8NRKD02360734A
    Intel Core i7 10th GEN
    NVIDIA GE FORCE RTX 2070
    Hello all, I have been researching an issue on my son's laptop. The laptop powers on, but has no video. The video briefly worked with the USB-C port, but has stopped displaying video all together. So, no HDMI, screen, or USB-C. It is starting up, I can see the backlight but no display. You can hear the annoying startup sound when it turns on. My son told me that it completed an update and then the issues began.
    After my research I have found that a lot of owners of these laptops have had issues after system updates. I have downloaded the boardview file and schematic. I can see that the board has 2 BIOS chips, and I am almost certain that the main BIOS chip is U2802 (MX25L12873FM2I-10G). There is another chip, U7802 (W25Q80EWSNIG-ND), but it is only an 8Mbit chip, which is too small to hold the main BIOS file from what I have learned.
    I have purchased a CH341A programmer and I will need a BIOS, so I can reprogram the chip. In my research I have also read that you cannot just upload a BIOS file that has been downloaded from the ASUS website. Is that correct? I want to do this correctly, so I will appreciate everyone's guidance before attempting to reflash the BIOS chip.
    I am new to this, so if my assumptions or understanding are incorrect, please feel free to correct me. I am here to learn from this experience and hopefully continue my learning experience.
    Thanks,
    Pete​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12396
    Originally posted by pete18064
    MB : G532LWS R1.3
    Thanks,
    Pete​
    Bios chip here.
    • pete18064
      • Jan 2025
      • 12
      Thanks hoaca388!
      I ordered a CH341a and was able to download the BIOS. Can someone please provide a new BIOS, or can I just download it from the ASUS website. I would like to learn how to do this with some guidance.
      Should I upload the bin file I downloaded from my BIOS IC?
      Thanks,
      Pete
      • hoaca388
        Badcaps
        • Jan 2022
        • 12396
        Thanks hoaca388!
        Thanks,
        Pete
        I need you to backup bios with your CH341A device, even if it is broken.
        This is the most important step when requesting bios repair.​
        • pete18064
          • Jan 2025
          • 12
          Hello hoaca388, I performed 3 dumps, compared the 3, and they are identical. I have saved the 3 files, so the backup part is done.
          I was going to use the firmwares provided in the following post, but I am not sure if that was the correct thing to do. https://www.badcaps.net/forum/troubl...es76-bios-help
          Here is the file.
          Thanks!
          • pete18064
            • Jan 2025
            • 12
            hoaca388, should I try the firmware from the post I listed above, or is too risky?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12396
              ROG Strix G15
              • pete18064
                • Jan 2025
                • 12
                hoaca388
                , or anyone else can chime in, since I am new to this I want to be sure that I have the correct IC identified as the BIOS chip. I have identified U2802 as the BIOS, but there are 2 ICs on this board and the other is U7802. Am I correct, that the BIOS is on U2802?
                Thanks,
                Pete
                • pete18064
                  • Jan 2025
                  • 12
                  Thank you hoaca388 for the FW. The laptop boots into the BIOS, but I get a flash of the logo, and then it goes to black screen the majority of the time.There have been times when it boots into the BIOS and the logo flashes in the center of the screen and it goes to black screen. Then, there have been times when it boots into the BIOS, but only half of the screen is visible. The BIOS screen is completely visible, cropped into half of the screen. What would the suggestions be in this case? I suspect the GPU has solder issues, but I am not sure.
                  • pete18064
                    • Jan 2025
                    • 12
                    I wanted to add that I checked to see if there was a display signal on USB-C and HDMI, but it was not present. Even when I get the two situations above I have no display on USB-C or HDMI. The backlight is working correctly, as far as I can tell. I have performed these tests with the drive disconnected. I figured if it has problems with the drive disconnected then it was and issue with the BIOS or the GPU. Please let me know what you guys think and what steps should I take now.
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
