Rog Strix G512LW-ES76 BIOS help
  • Fabregasronaldsr
    • Jan 2015
    • 15
    • Philippines
    I need assistance in resolving issues with an ASUS ROG Strix laptop, specifically the model GL512LW-ES76. The laptop was taken to another repair shop, but they failed to back up the original BIOS file. After replacing the PCH and reprogramming the BIOS using the provided file, I am experiencing problems with the LAN, video card, and Wi-Fi functionalities. Could someone please help me rectify the BIOS file to resolve this issue? I am facing a dilemma as I do not possess the original BIN file.
    Model: G512LW-ES76
    Board Model: G532LWS R1.3
    SN: LANRKD02394842B
    Specs: Intel Core i7-10750H, RTX2070, 15.6 240hz
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    Re: Rog Strix G512LW-ES76 BIOS help
    Model: G512LW-ES76
    SN: LANRKD02394842B
    Try
    • Fabregasronaldsr
      • Jan 2015
      • 15
      • Philippines
      Thanks hoaca388, tried your Bin file, NO Display
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Model: G512LW-ES76
        SN: LANRKD02394842B
        your posted bios is original and dmi match with that bios
        and it was clean and configured already
        BTW i try to fix it you may try
        • Fabregasronaldsr
          • Jan 2015
          • 15
          • Philippines
          Thanks @qayyum786, still the same Error in graphics and wifi card
          is it possible that the problem still in PCH or bad/cold solder?
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            because some one play already in bios before you so i think bios still could be an issue
            before you touch PCH
            you may try another bios file rather than original (third party bios from other laptop) if still no luck than only fall in to a hardwear
            • Fabregasronaldsr
              • Jan 2015
              • 15
              • Philippines
              Update: after replacing new PCH again and using your bios @gayyum786, All device working properly now! thanks all!
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                glad to hear that
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • maanee11
                  Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                  by maanee11
                  Hello Everyone,
                  I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                  It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                  In the website, you can only see specs etc.
                  I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                  11-08-2025, 04:08 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
