Need a Bios vor an HP Notebook 15-fc0153ng
  • Maddin99
    • Jan 2025
    • 5
    • Deutschland
    i need a Bios File vor HP Notebook 15-fc0153ng please!
    Kind regards Martin
  • peste
    • Dec 2016
    • 13691
    • ROMANIA
    Kind regards Martin
    post the contents of the bios chip even if it is corrupted..post S/N, motherboard model, product number,etc.
    • Maddin99
      • Jan 2025
      • 5
      • Deutschland
      i need a Bios File vor HP Notebook 15-fc0153ng.
      SN# 5CD3125BVH
      ProdID 7N6C9EA#ABD
        SMDFlea commented
        Editing a comment
    • Maddin99
      • Jan 2025
      • 5
      • Deutschland
      Click image for larger version  Name:	IMG_9946.jpg Views:	0 Size:	491.3 KB ID:	3543827
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Okay, this is your BIOS chip and it's 1.8v so you will have to use 1.8v adapter if your programmer doesn't support that voltage.
      You will have to read the content of this chip and upload it here to let us help you.
      all donations are welcome,
      • Maddin99
        • Jan 2025
        • 5
        • Deutschland
        Here is the bios file from the laptop
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          You can try this file, it's a virgin BIOS from HP without DMI.
          • Martin99
            • Jan 2025
            • Deutschland
            unfortunately the bios doesn't work.
            • Maddin99
              • Jan 2025
              • 5
              • Deutschland
              The Motherboard is:
              MODEL BOARD DA00PDMB8E0 REV E
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                Today, 04:08 AM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
