Lenovo Y700-15ISK need EC bios after EC replace
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    I replace EC on this y700-15ISK nm-A541 but need EC firmware to flash it.
    Anyone have it?
  • vanminhscdt@gmail.com
    • Jul 2022
    • 74
    • Việt Nam
    Originally posted by ktmmotocross
    Hello.
    Anyone have it?
    Why did you replace it? What is the EC name?
      • 21980
      Hello.
      Anyone have it?
      Post the laptop serial number , Model Type , motherboard model number and revision if any. Post your bios backup, depending on what EC it has it might be in the bios and it could possibly be extracted.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        No SN because i have only board and lcd. nm-A541 rev. 1.0, bioses was allready flashed by unknown fw. so i will be flashing what u point at. there is few threads here
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Try
          posted EC+MAIN
          • aldred43@gmail.com
            Avgans
            • Jan 2025
            • Финляндия
            Hello. There is a burnout of the p601 chip. Do I need its firmware when replacing it with a new one? Or is it possible to install from a similar board without firmware?
            And unfortunately, I have not found out the name of the chip if I order a new one.
            • peste
              • Dec 2016
              • 13656
              • ROMANIA
              if the bios chip is burned, you can take a similar chip from another board, but it must be written with the bios for the motherboard where you solder the chip...
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • grimacelord
                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                by grimacelord
                Hello there.
                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                History:
                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                I searched for this error online and discovered...
                03-15-2023, 03:29 PM
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • mkdj
                Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                by mkdj
                Dear all,
                I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                Here the steps I have taken to fix the laptop:
                - downloaded latest BIOS from Lenovo Website...
                10-18-2025, 03:43 AM
