b1402cba_mb rev 2.1 need bios dump
  • kutsuy
    • Dec 2022
    • 7
    • ukraine
    Hi friends,need bios dump from ASUS Expertbook B102CBA-BQ0495,motherboard b1402cba_mb rev 2.1
    Thanks!
    • 20304
    Thanks!
    Post your bios backup and the required laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
    • kutsuy
      • Dec 2022
      • 7
      • ukraine
      Here is my bios(no init)
      laptop serial:R5NXCV02E69218B
      • hoaca388
        Badcaps
        • Jan 2022
        • 11191
        • Viet Nam
        B1502CBA
        • kutsuy
          • Dec 2022
          • 7
          • ukraine
          Originally posted by hoaca388
          B1502CBA
          thanks, but it doesn't work for me.Maybe you have a different bios?
          • noname2024
            • Aug 2024
            • 198
            • CỎ MỸ XỊN
            Model: B1502CBA
            • kutsuy
              • Dec 2022
              • 7
              • ukraine
              Originally posted by noname2024
              Model: B1502CBA
              my model is
              b1402cba_rev 2.1
              • noname2024
                • Aug 2024
                • 198
                • CỎ MỸ XỊN
                my model is
                b1402cba_rev 2.1
                Check sn is model b1502cba
                • kutsuy
                  • Dec 2022
                  • 7
                  • ukraine
                  I mean the motherboard model. I tried to flash it - it starts for 3 seconds and turns off. The backlight on the keyboard flashes 1 time. With my BIOS it turned on, the processor warmed up, the backlight on the keyboard was constantly on, all voltages were present - except for the video core power supply.
                  • kutsuy
                    • Dec 2022
                    • 7
                    • ukraine
                    I found the bios. my bios is perfectly fine, the problem is something else. who needs it, you can use my dump
                    • rookieme
                      • Oct 2014
                      • 396
                      • Greece
                      Can somebody try to fix my bios too?
                      After kcb replacement system was not working properly and had old bios version. After bios update it boots no more.
                      I have included the serial number in the zip.
                      So far I have tried to fix it by replacing the bios region from asus with no luck.
                    • noname2024
                      • Aug 2024
                      • 198
                      • CỎ MỸ XỊN
                      Model B1402CVA B1402CVA.zip
                      • rookieme
                        • Oct 2014
                        • 396
                        • Greece
                        Thank you for your reply, your bios works but I have more issues.
                        If I update it to latest version it boots no more like the original one.
                        Also I haven't managed to program the kbc that I have replaced and keyboard hasn't worked so far.
                        I'm sharing the EC file I have extracted from bios if anyone needs it.
                        Also the pin layout as mentioned at a paid site for kbc programming is:
                        KB_pins=30 08MM LEFT DOWN PD0=4 PD1=5 PD2=6 PD3=8 PD4=9 PD5=10 PD6=11 PD7=12 BUSY=15 STB=1 AFD=2 INIT=3 SLIN=7 KSI4=14 KSI5=16
                        But i haven't managed to make it connect to my programmer so far in order to confirm it is correct.
                        • noname2024
                          • Aug 2024
                          • 198
                          • CỎ MỸ XỊN
                          Try last bios ver 310 B1402CVA ver 310.zip
                          • rookieme
                            • Oct 2014
                            • 396
                            • Greece
                            Try last bios ver 310 [ATTACH]n3576736[/ATTACH]
                            Thank you for your time.
                            I'm writing to tell you that I have a second issue but both of your bios files work ok.
                            • JarzabekPZ
                              • May 2023
                              • 10
                              • Poland
                              Can you help me with bios password clearing? In my bios dump there is no code after AMITSE,
                              B1502CBA-NJ1761XA
                              board b1402cba_mb
                              sn: R7NXCV190186308
                              • peste
                                peste commented
                                Editing a comment
                                post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                            • peste
                              • Dec 2016
                              • 12254
                              • ROMANIA
                              B1502CBA-NJ1761XA
                              board b1402cba_mb
                              sn: R7NXCV190186308
                              post full name and model, etc.
                              • JarzabekPZ
                                • May 2023
                                • 10
                                • Poland
                                ASUS ExpertBook B1502CBA-NJ1761XA
                                • peste
                                  • Dec 2016
                                  • 12254
                                  • ROMANIA
                                  admin password Tomek2006
                                  boot password Bartek2013
                                  • JarzabekPZ
                                    • May 2023
                                    • 10
                                    • Poland
                                    Thanks!
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • grimacelord
                                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                      by grimacelord
                                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                      Motherboard model number: DA0PAMB46A1 REV: A
                                      Secondary motherboard model number: 0PAB
                                      SKU: 685K4UA
                                      Serial number is: 5CD3223BJP
                                      Recently reflashed this laptop with latest BIOS and once...
                                      05-07-2024, 08:06 AM
                                    • DynaxSC
                                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                      by DynaxSC
                                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                      11-06-2022, 05:22 PM
                                    • vinaypundith
                                      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                      by vinaypundith
                                      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                      So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                      08-03-2024, 12:32 PM
