HP 15-BC DAG35NMB8C0
  • max2711
    • Jan 2012
    • 62
    • Croatia
    Hi
    need EC dump for HP 15-BC504, DAG35NMB8C0, IT8987E.
    Thank you
    • 20643
    Originally posted by max2711
    Hi
    Thank you
    Post the laptop serial number.., and your bios backup. The EC can be extracted from the bios.
    • max2711
      • Jan 2012
      • 62
      • Croatia
      sn: 5CD020BRG4
      • peste
        • 12601
        • ROMANIA
        sn: 5CD020BRG4
        try..
        • fiala985
          fiala985
          • Jul 2024
          • 19
          • Slovakia
          Model : HP. 15-bc502nc
          SN : 5CD9300WZ2
          RMN : TPN-Q173
          prodID : 7BU90EA#BCM
          motherboard : DAG35QMB8C0 rev:C Model : G35Q
          good day, I need to create a bios and ec with the original site or the chips I have already created are damaged by a short on the 3v line​
            • 20643
            SN : 5CD9300WZ2
            RMN : TPN-Q173
            I found your request at other sites, you changed the PCH ?
            • fiala985
              fiala985
              • Jul 2024
              • 19
              • Slovakia
              Hello, yes, the pch chip was changed
                • 20643
                Here`s a virgin bios + EC. If it doesn`t boot it could be the PCH that isn`t soldered correctly or the wrong one if you bought a used one with bootguard, or the problem could be somewhere else.
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Mephysis
                  DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                  by Mephysis
                  Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                  I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                  03-27-2025, 02:34 AM
                • Andreas_de
                  Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                  by Andreas_de
                  Hello!
                  i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                  Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                  Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                  04-12-2025, 10:38 AM
                • re-atari
                  Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                  by re-atari
                  Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                  Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                  02-03-2025, 06:49 PM
                • Buzzfuzz2k
                  Bios password removal on a Unowhy dump
                  by Buzzfuzz2k
                  Hi Everyone,
                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                  the Computer is a Unowhy small pc
                  N° UYM6524702229
                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                  My first attempt was to get the bios dump from windows...
                  11-13-2023, 07:37 AM
