Thoughts on Reverse Engineering 8FC8 suffix logic..
  • nix30101
    • Dec 2019
    • 26
    Greetings i am in the process of reverse engineering the bios logic for the 8FC8 suffix so far I have found most of the bios functions related to the suffix from a bios dump and I have verified inputs and outputs to test with plus the chartable for the 8FC8 suffix.
  • black0hackers
    • Jul 2020
    • 367
    [QUOTE=nix30101;n3529696]Greetings i am in the process of reverse engineering the bios logic for the 8FC8 suffix so far I have found most of the bios functions related to the suffix from a bios dump and I have verified inputs and outputs to test with plus the chartable for the 8FC8 suffix.[/Q
    how good!
    • kuiri
      • Jun 2024
      • 11
      I just thought about it, and decided to give it a good 'ol google search... and comes along your post on the 3rd result lol
      Have you had any progress? I mean it shouldn't be impossible or if I could take a guess at least, something that has been done before.
      I found there's people on the fleabay selling you a master password for 75 dollars, and has over 180 combined sales so far... Also in the BIOS of all of these newer models the "Master Password Lockout" option still exists. Which means they have a master password.
      Just my 2 cents.
      • LBTT1121
        • Nov 2024
        • 737
        • Việt Nam
        Just my 2 cents.
        Search REX 8FC8 Done 100%
        • nix30101
          • Dec 2019
          • 26
          RE still in the works, but in the meantime, the next best thing is the updated Python script
          https://github.com/chromebreakerdev/DellBIOSTools.git based on REX 8FC8. You can download just the raw Python file "dell_bios_tools.pyw" if you prefer. It has the 8FC8 patcher tool and old Dell master password generator combined.
          • kuiri
            • Jun 2024
            • 11
            I am aware of REX's patch, it works wonderfully; but I meant reverse engineer the master password... not modify the contents of the BIOS flash chip.
            • nix30101
              • Dec 2019
              • 26
              Yes, the master password algorithm is present on "8FC8" devices, just like in older BIOS versions.
              • talhoid
                • May 2025
                which UEFI module are you looking in to find the logic? can you share the bios dump? the bios i've dumped from the update exe files only contain the logic for the E7A8 suffix.
                ive looked in SystemPwSmm and PasswordMgrDxe. they seem to be related.
                • vidvansh
                  • Mar 2025
                  • 25
                  I have seen there are some sellers on ebay which are charging 120 aud for the master password. I am also interested in learning and reverse engineering about it but i have no idea where to start from.
                  • nix30101
                    • Dec 2019
                    • 26
                    Using Ghidra, I've extracted the chartables for the 8FC8 suffix. The BIOS is the full BIOS 16M file, not the update. I've dump quite few 8FC8 bios's they all have the same functions in Ghidra, which point to functions used in 8FC8 logic. I've exhausted the static references and will be doing more work with live bios dumps via binwalk etc.
                    • nix30101
                      • Dec 2019
                      • 26
                      That's nuts. Just use a BIOS programmer and the apps.
                      • JAFATAGNA
                        DELL XPS 9315 bios Password 8FC8 Suffix
                        by JAFATAGNA
                        plzz need help remove password 8FC8 Suffix...
                        09-07-2023, 02:36 PM
                      • spleenharvester
                        Reverse engineering of DoCreate DHJ567 handheld spot welder
                        by spleenharvester
                        Hello everyone
                        I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                        Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                        05-08-2025, 02:52 PM
                      • learnmore
                        Removing master password on 7220 with 8FC8 suffix
                        by learnmore
                        Hello Community,
                        I'm attempting to reset the BIOS on a Dell 7220 rugged laptop.
                        It's a 8FC8
                        SN:7Q2PTG2
                        I've read a great post by Pier on this forum but there are some gaps in my knowledge.
                        Is there are paid program or way to get the master password?
                        If not what programmer should I get Svod3/4?
                        What software should I use with the programmer?
                        Where is the BIOS chip located on this computer model?
                        How to skilled members on this forum cook a new BIOS to remove the master password?
                        06-08-2023, 04:12 PM
                      • skinner
                        Dell Latitude 9510 Bios Password With 8FC8 Suffix
                        by skinner
                        Looking for some help with a bios password. Any help would be appreciated.
                        Dell Latitude 9410
                        Service Tag - H803043
                        Board - LA-J541P REV 1.0...
                        05-17-2024, 04:02 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
