Please bios NM-B902 T490 gen 10
  • tdelfy
    • Aug 2014
    • 111
    • usa
    S/n PF-270Z1F
    • 21196
    Explain what the problem is.
    • tdelfy
      • Aug 2014
      • 111
      • usa
      bios no display and beep beep
      • alexch2013
        • Nov 2023
        • 6
        • china
        You can first try to see if the external HDMI display is normal? If it is normal, it should be that the output LCD panel line on the motherboard is NG.
          • 21196
          Try this one.
          T490 (Type 20RY, 20RX) Laptop (ThinkPad) - Type 20RY
          • tdelfy
            • Aug 2014
            • 111
            • usa
            Originally posted by SMDFlea
            Try this one.
            no power
            • LEO037_2029_
              BIOS_LEGEND
              • Nov 2023
              • 83
              • Argentina
              tdelfy hi. try my bios. and teel me if work for you ,, give feedback
              • tdelfy
                • Aug 2014
                • 111
                • usa
                thanks my friend but t490 cpu error
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • traxformania
                  TONGFANG "GM7TG7P" Bios Password Problem?
                  by traxformania
                  I tried :
                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                  11-15-2023, 07:32 AM
                • trouble55
                  NEC VersaPro PC-VRT42FBFR22B BIOS problem
                  by trouble55
                  Hi All,
                  [Mother board model]
                  V-VE212(U3E1)
                  [Serial number]
                  24000135PA
                  [BIOS chip model]
                  Macronix MX77L12850F
                  I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                  I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                  I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                  09-19-2024, 01:24 AM
