S/n PF-270Z1F
Please bios NM-B902 T490 gen 10
Explain what the problem is.
You can first try to see if the external HDMI display is normal? If it is normal, it should be that the output LCD panel line on the motherboard is NG.
Try this one.
T490 (Type 20RY, 20RX) Laptop (ThinkPad) - Type 20RYAttached Filesif you find these attachements useful please consider making a small donation to the site
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... -
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... - Loading...
