LENOVO X1 Yoga 4TH - BIOS REQUEST
  • Miinoru
    • Dec 2024
    • Yucatan
    Model: LENOVO X1 Yoga 4TH
    Motherboard: GX490 NM-C661 REV 1.0
    PF-2CNW6P
    20SBS0HV00
    Bios: MX25l8006E
    I have searched the forum and found many 32MB versions but when installing it won't let me. When I search for the specifications of the MX25l8006E it shows me 8MB. I supposedly made a backup but it only weighed 1MB. someone can help me T_T
  • hoaca388
    Badcaps
    • Jan 2022
    • 12178
    PF-2CNW6P
    20SBS0HV00
    Bios: MX25l8006E
    MX25l8006E contains 1MB of data, that's right. You have selected the wrong chip. Choose the chip with the number 256 on it. For example: 25Q256JVSQ
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • AYsys
      Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
      by AYsys
      Hello dear forum members,
      I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
      I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
      Nothing was flashed here — the BIOS was only backed up.
      I created the backup using a CH341A Black programmer and NeoProgrammer....
      09-13-2025, 11:05 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • HotSaladMan
      Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
      by HotSaladMan
      *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
      Model : Lenovo ThinkBook 14S Yoga ITL
      S/N : MP28JT19
      MFG Date : 2022/02/09
      Factory ID PRC4
      MO : MPNXB26080FX
      MTM : 20WE001US
      MODULE FCC ID : PD9AX201NG
      IC : 1000M-AX201NG
      BOARD INFO
      FLV34 LA-KO51P
      REV : 1B 2020-08-24
      Bit of Info
      Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
      chip id, so i would always uncheck the id check, so it would bypass the error
      i did in fact make...
      11-07-2024, 07:46 AM
    • beogeek
      Lenovo Yoga Slim 7 14APU8 Bios Request
      by beogeek
      I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
      Attached is the bios dump in the state I received it...
      10-24-2024, 12:54 PM
