HP 15-da0117nl Lost BIOS info and no TPM
  • DarthMick
    • Nov 2024
    • 7
    • Italy
    Hi guys,
    i own an HP laptop that suddenly lost all info in the BIOS (serial number, model number, UUID and so on) and the TPM module that used to work is no longer recognized.
    I have Windows 11 installed, but it keeps trying to reinstall the system files without success because the TPM is not present.
    Now i need anyone here to tell me which tools i need to try to reprogram the BIOS and reactivate the TPM module.
    The laptop data are:
    S/N: CND838BGBD
    4TW61EA#ABZ
    Model 15-da0117nl
    RMN:TPN-C135
    โ€‹
    Many thanks!!!
    Mick
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Should be posted in "Bios Forum" and not here.
      • 21649
      Originally posted by DarthMick
      Hi guys,
      S/N: CND838BGBD
      4TW61EA#ABZ
      Model 15-da0117nl
      RMN:TPN-C135
      โ€‹
      Many thanks!!!
      Mick
      Thread moved to bios requests forum. Post your bios backup in a zip/rar attachment.
      • DarthMick
        • Nov 2024
        • 7
        • Italy
        I can make a backup of the actual BIOS, i don't have one made before things went wrong...Will that suffice?!?
          • 21649
          It will have to do, yes go ahead and post it.
          • DarthMick
            • Nov 2024
            • 7
            • Italy
            OK, here it is:
            • minhdigital
              • Nov 2022
              • 764
              • Vietnam
              OK, here it is:
              Your bios is new so there is no information, please try to fill in more information.
              • DarthMick
                • Nov 2024
                • 7
                • Italy
                Thanks for your reply but...What kind of additional info do you need?!? And what i'm supposed to do with the attached 1.rar file?!?
                I apologize, but i'm kinda new to BIOS programming.
                • DarthMick
                  • Nov 2024
                  • 7
                  • Italy
                  i own a HP 15-da0117nl with lost info (serial number, etc) and other functions like TPM.
                  I have created an HP Recovery Key from another identical laptop, but i can't rewrite the BIOS entirely...In detail:
                  If i leave the SSD with the operating system connected, the Win-B process will start and finish, but the BIOS will remain the same.
                  If i remove the SSD and try the Win-B procedure with just the USB Key connected, the computer says that it cannot find the recovery files from the USB key.
                  Is there another way to fully recover my BIOS?!?
                  Many Thanks!!!โ€‹
                    • 21649
                    Many Thanks!!!โ€‹
                    Thread merged with your previous topic. Try to enter the serial number etc using HP Bios Config Utility https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html .If that doesn`t work you will need to buy an SPI programmer to flash a new bios.
                    • DarthMick
                      • Nov 2024
                      • 7
                      • Italy
                      Thanks for your reply...I have already tried with BCU, but basically it says the BIOS is not in MPM mode so no luck...It looks like my only chance is having someone to reprogram the BIOS chip with an SPI programmer, am i right?!?
                      • macabook
                        ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
                        by macabook
                        Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
                        ๐Ÿงฉ Initial Issue
                        07-24-2025, 02:17 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • grimacelord
                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                        by grimacelord
                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                        Motherboard model number: DA0PAMB46A1 REV: A
                        Secondary motherboard model number: 0PAB
                        SKU: 685K4UA
                        Serial number is: 5CD3223BJP
                        Recently reflashed this laptop with latest BIOS and once...
                        05-07-2024, 08:06 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
