MSI GF65 MS-16W21 rev, 1.0 - Clean Me Bios please
  • mavaro
    • May 2017
    • 28
    • Polska
    After replacing the PCH bridge, no image - it is necessary to clear the region. Can anyone help? Attached is the bios​
  • shiyab
    • Sep 2023
    • 1448
    • india
    need model
      • 20855
      Post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
      Whenever the PCH is replaced the ME firmware must always be cleaned. There are some guides if you want to have a go at it yourself https://www.badcaps.net/forum/troubl...22#post1622422
      If there is a full bios image at MSI support you don`t need to clean the ME as it will be clean and configured already, just copy any DMI info or windows key from your backup to the new image.
      • mavaro
        • May 2017
        • 28
        • Polska
        I don't have the serial number, it's blurred on the case, the model is MSI GF65 THIN 10UE MS-16W2 MS-16W21 motherboard Intel 10gen, PCH: Intel HM470 SRJAU, motherboard: 16W21 rev. 1:0 i7-10750H RTX 3060
        • noname2024
          • Aug 2024
          • 236
          • CỎ MỸ XỊN
          try
          • teptronics
            • Sep 2021
            • 15
            • philippines
            Hi guys can somebody help me to retrieve EC bin file from this bios.
            EC chip already damage and can't EC bin cant be extracted from there.
            Thanks a lot. Orig BIOS dump attached.
            MSI GF65
            MS-16W21
            • peste
              • Dec 2016
              • 12787
              • ROMANIA
              MSI GF65
              MS-16W21
              post S/N and try..
              • teptronics
                • Sep 2021
                • 15
                • philippines
                Originally posted by peste
                post S/N and try..
                Thanks again.
                Update, already successfully flash EC using this BIN but machine not turning ON, led indicator will lit split seconds after pressing power button.
                3.3v present on EC chip caps.
                +3VALW and +5VALW also present on TPS51225c step down IC.
                +5VSUS and +3VSUS is not present when power button is not press, (present when pressed) which I think normal on MSI GF65 laptop not sure though.
                Orig bios bin file still attached to extract EC bin file. Original EC chip already burnt and cannot extract EC bin from there.
                Model: MSI GF65 THIN
                Board: MS-16W21
                S/N: K2107N0134519
                • peste
                  • Dec 2016
                  • 12787
                  • ROMANIA
                  Thanks again.
                  Board: MS-16W21
                  S/N: K2107N0134519
                  Bios and EC bios extracted from MSI website update for GF65 Thin 10UE..
                  • teptronics
                    • Sep 2021
                    • 15
                    • philippines
                    Thank you, already tried flasing both EC and BIOS still same result.
                    What could be the possible issue?
                    Power led will just flash when pressing power button and board suddenly take 100mA current and back to zero for split second after pressing ON.
                    Thanks.
                    • Iamjay
                      • Jun 2025
                      • 6
                      Hello all i have recently purchased a MSI laptop model number MS-16W2 with serial number K2109N0025403. this was a gift from my girlfriend and she is not very tech-savvy as she did not even turn on the laptop when she purchased the thing from the guy. I have tried to do all the things stated online to clear this password and I am hoping one of your brillant lads can help me get this computer up and running. i was an electrical engineer until 4 years ago when i was hit by a car on my motorcycle and I have some new metal in my arms and legs and a bit of a head injury so please be simple with bany help you can provide me. thanks for your time and i look forward to hearing back from you guys
                      • peste
                        peste commented
                        Editing a comment
                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                    • peste
                      • Dec 2016
                      • 12787
                      • ROMANIA
                      post full name and model, etc.
                      post the contents of the bios chip even if it is corrupted..
                      • Focus2005
                        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                        by Focus2005
                        Hello everyone.
                        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                        05-01-2025, 05:41 AM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • grimacelord
                        Latitude E6530 - Trouble Extracting BIOS Image From EXE
                        by grimacelord
                        Hi folks,
                        I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                        Service tag number for this model is: "JYDWYW1".
                        Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                        I have tried:
                        • Simply extracting with 7zip
                        • PFSExtractor
                        • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                        • Check Temp folder
                        10-26-2023, 08:15 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
