ASUS X512FF Rev 3.1 Help to find the KBC dump
  • korsar86
    • Sep 2018
    • 33
    • RF
    Asus X512FF (X512FLC) REV 3.1
    Help to find the KBC dump for this model.
    The laptop works. but there is a problem, after power off it no longer responds to the power button, that is, you have to reset the battery and it turns on again (autostart).
    There is also no keyboard backlight and the touchpad does not work.
    The multicontroller is responsible for controlling these functions. Before I replace it, I would like to flash it first. thank you
    Attached is a picture of the sticker and the native dump.
  • shiyab
    • Sep 2023
    • 1626
    • india
    post main bios and snid
    • korsar86
      • Sep 2018
      • 33
      • RF
      Unfortunately I can't find the SNID.
      The lettering on the case is obliterated
      I have attached the original bios dump
      • shiyab
        • Sep 2023
        • 1626
        • india
        hi try 256
        • jemi
          • Jun 2022
          • 3
          • Indonesia
          try
          • korsar86
            • Sep 2018
            • 33
            • RF
            Unfortunately changing the bios did not help, I will try to change the multicontroller
            • Dezolator
              • Nov 2021
              • 7
              • Slovensko
              I need new EC firmware for the X512FF rev 3.1 board. The original one is probably defective, the keyboard doesn't work from time to time. The one posted above can no longer be downloaded.
              • peste
                • Dec 2016
                • 13661
                • ROMANIA
                post S/N, full name and model, motherboard model, etc.
                post bios EC and main...
                • Dezolator
                  • Nov 2021
                  • 7
                  • Slovensko
                  I couldn't read the original EC firmware. The programmer doesn't want to communicate with the chip. It's probably defective. So I can't do anything with it now.
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • kodox
                    Asus ExpertBook B1400CB Bios Dump Needed
                    by kodox
                    need original bios dump, original bios has flashed by other technician before me.
                    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                    unit info:
                    Model: Asus ExpertBook B1400CBA-0711A1235U
                    S/N: R6NXNZ006657238
                    CN: 7F6F
                    Mainboard Code: B1500CBA R2.1...
                    08-16-2025, 12:20 PM
                  • kcp0085
                    Request BIOS dump for ASUS FA617NS
                    by kcp0085
                    Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                    I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                    Specs:
                    - ASUS TUF FA617NS-A16
                    - CPU: AMD Ryzen 7
                    - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                    If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                    Thanks in advance!
                    05-02-2025, 12:52 AM
                  • Tamo Neko
                    Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                    by Tamo Neko
                    I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                    What Happened:
                    I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                    • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                    • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                    What I Need:
                    • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                    02-12-2025, 11:29 PM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
