HP DM1-4000er Bios Dump needed
  • James Maxwell
    KnowledgeSeeker
    • Jan 2024
    • 8
    • TURKEY
    I badly need bios dump for HP DM1-4000er,
    Model: HP DM1-4000er
    Motherboard: DA0NM9MB6D0 REV.D
    Product: QJ490EA#ACB
    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
    • 20949
    post the laptop serial number
    • James Maxwell
      KnowledgeSeeker
      • Jan 2024
      • 8
      • TURKEY
      My laptop serial number is 5CD1425H6X
      Thank you for your help.
      • James Maxwell
        KnowledgeSeeker
        • Jan 2024
        • 8
        • TURKEY
        I thought or at least hoped you wrote this with the intention of giving me the file, I suppose I was wrong 😊
        Any help would be greatly appreciated.
        • James Maxwell
          KnowledgeSeeker
          • Jan 2024
          • 8
          • TURKEY
          I would like to bump this topic in case someone might help.
            • 20949
            Bumping after 5 hours... not very patient are you.
              • 20949
              here
              • James Maxwell
                KnowledgeSeeker
                • Jan 2024
                • 8
                • TURKEY
                To be fair, it has been 5 days, I just thought you weren't going to reply
                Still, you are right and I am sorry. It is just that I can't find the file I am looking for and I don't know what else to do.
                Meanwhile I flashed a bios file I found somewhere, it didn't exactly work, but now when I press the button the power led blinks white 3 three times and nothing else happens. No fan spin or caps lock light whatsoever. I read somewhere it is because battery completely drained, but I don't have a spare. I left it for charging all night but nothing seemed to happen.
                here
                Thank you, but this file days Rev.C and my motherboard Rev.D, would it still work?
                Only reason I am double checking is, each time I have to desolder and solder back on the bios chip and with basic tools that I have is bit of a challenge.
                  • 20949
                  It`s the right bios. The one posted above is version F16, i found a newer one, version F19 .
                  • James Maxwell
                    KnowledgeSeeker
                    • Jan 2024
                    • 8
                    • TURKEY
                    Thank you, I will try it as soon as I can
                    • James Maxwell
                      KnowledgeSeeker
                      • Jan 2024
                      • 8
                      • TURKEY
                      I am sad to say that it did not work. I was getting 3 blinks from power led before, now after flashing that I am not getting anything at all.
                      I don't rightly know why, but this suggest one of three things,
                      1. Something went wrong with my motherboard,
                      2. I did not solder the bios ship correctly
                      3. The bios you shared and my motherboard is not compatiple.
                      Last one seems like a distinct possibility, mainly because:
                      The bios you shared: DANM9GMB6C0 Rev.C.
                      My motherboard: DA0NM9MB6D0 REV.D
                      Not exactly the same. Something might be different.
                      By the way, was I supposed to edit the bios you sent me in any way? I noticed the one you shared don't have the information it would normally have at the beginning.
                        • 20949
                        The bios is missing the DMI information as it`s a virgin bios. It should have booted without the DMI. If it had booted you wcould have filled in the missing DMI with HP DMI tools, nbdmifit.
                        Those are the only bios i could find,and i`m sure it`s for your laptop regardless of the motherboard revision number.
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
                        • vinaypundith
                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                          by vinaypundith
                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                          08-03-2024, 12:32 PM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • rednix01
                          Nuc7i5BNH Bios Dump Needed
                          by rednix01
                          I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                          Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                          I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                          06-19-2025, 06:37 PM
