Lenovo T580 Bios Request
  • jomerfx28
    • May 2020
    • 31
    • n/a
    I've got a system here Lenovo T580- SSD NVme damaged. we replaced the ssd, however it doesnt boot nor detect the new ssd, so could be bios is corrupt.
    Lenovo t580
    P/N SL10T84532
    S/N R90VTEDC
    Type 20LA-S1V100
  • shiyab
    • Sep 2023
    • 1592
    • india
    Lenovo t580
    P/N SL10T84532
    S/N R90VTEDC
    Type 20LA-S1V100
    SNID NO CHEK
    • Markus1741
      • Sep 2020
      • 920
      • N/A
      Lenovo t580
      P/N SL10T84532
      S/N R90VTEDC
      Type 20LA-S1V100
      I think your BIOS backup is okay, but try this.
      https://www.badcaps.net/forum/troubl...cted#post96321
      • jomerfx28
        • May 2020
        • 31
        • n/a
        Thanks. it was not a faulty Bios - cable is incorrectly installed, anyways, the lock in port also, some pins are partly loosed, so i soldered them. the cable is somehow, pulling up the port, not a perfectly designed port
        • Tix2
          • Feb 2014
          • 62
          i have here an Lenovo T580.
          SN: R9-0THEEQ
          Mod.: 20LA-S54S00
          First it shows no screen and after i reflash the BIOS from this Website i have screen but the Security Chip is at 1.2 and MFG Mode.
          I cannot install WIndows 11.
          Can someone help me.
          I search the Forum and found nothing about that.
          I attach the Bios that i reflash.
          Thank you in advance.
          Best regards
          • peste
            peste commented
            Editing a comment
            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • grimacelord
          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
          by grimacelord
          Hello there.
          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
          History:
          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
          I searched for this error online and discovered...
          03-15-2023, 03:29 PM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • HammyCheesy
          Lenovo ThinkStation P720 BIOS Request
          by HammyCheesy
          Hello all,
          I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
          When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
          Type: 30BB
          Model Number: S03600
          S/N: MJ07N68C
          Things I have tried:
          1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
          2. Attempted to boot with just a single CPU...
          04-11-2025, 01:02 AM
        • pauleccleston
          Lenovo E585 corrupt BIOS
          by pauleccleston
          Issue: Windows Update pushed a broken BIOS update to the machine, resulting in a total lock up during BIOS update and bricking of the machine (no screen output, CAPS lock permanently on, only fan turning and power LED on). If anybody could help with getting the machine back up and running i would be extremely grateful.
          Details as follows:-
          Make/Model: Lenovo/E585 (Laptop)
          Type: 20KV-CTO1WW
          S/N: PF-1PFYB3 19/04
          BIOS chip: Winbond 25Q128FWSQ 1844
          Dump of corrupt BIOS attached as zip.​...
          05-12-2025, 04:47 AM
