Bios panasonic FZ-M1CCFCXBM (mk1)
  • deitier
    • Aug 2006
    • 7
    Could someone please provide bios for panasonic FZ-M1CCFCXBM (mk1)
    thank you in advance.
    • 21679
    Post serial number, backup, issue description
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    https://www.badcaps.net/forum/troubl...ore-posting​
    • deitier
      • Aug 2006
      • 7
      Serial # 5CTYA32089
      Backup : missing
      issue : corrupted bios won't detect (recognize) hard drive .
      I check motherboard for any visible damage and I found none, check for possible short circuit and nothing (use multimeter and thermal camera).
      thanks in advance for any help.
      best regards.
        • 21679
        Do you have an SPI programmer to make a backup of the bios chip ? , if you do,what model is it and the software version. Are you able to detect the bios chip
        • deitier
          • Aug 2006
          • 7
          I have the TL866II Plus Programmer, software version 12.67 , yes the bios is detected , I just forget to make a backup when I disassemble the unit, do you have a bios for this device?
          thank you and best regards.
            • 21679
            No, i don`t have a bios.
            • deitier
              • Aug 2006
              • 7
              thank you, have a wonderful day.
              • AquaMan Ua
                Problem with PANASONIC CF53 laptop after changing BIOS settings
                by AquaMan Ua
                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                05-17-2025, 09:40 AM
              • aa10aa10
                Panasonic Toughbook CF-33 mk1 BIOS repair
                by aa10aa10
                Good day,
                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                01-21-2025, 06:13 AM
              • Teban1306
                [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                by Teban1306
                Hello everyone!
                I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                System Information:
                • Model: Lenovo ThinkPad T14 Gen 1
                • Machine Type: 20S1S4E600 (Intel i7 variant)
                • Current BIOS: N2XET42W (1.33) - Latest version
                • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                What I'm trying to achieve:
                Replace the default "LENOVO" boot logo with a custom image during POST.
                🔧 What I've tried:
                09-14-2025, 11:49 AM
              • James Jackson
                Panasonic CF-20G0247VM BIOS Bad Flash Help
                by James Jackson
                I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                05-01-2025, 11:28 AM
              • Chris_stand
                Clevo PD50PNN won't boot after BIOS Backup
                by Chris_stand
                i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                But the...
                04-28-2023, 03:08 PM
