HP 15fq2045nt - 2N2N8EA Bios needed
This topic has been answered.
  • Code7
    • Dec 2020
    • 8
    • Turkey
    can some clear me for me?
    Model : 15fq2045nt
    Part no : 2N2N8EA
    Serial : 5CD048C6CS
    Board : DA0P5HMB8E0 REV : E
    ​Thank you very much.
  • Answer selected by Code7 at 10-10-2024, 01:42 AM.
    peste
    • Dec 2016
    • 13641
    • ROMANIA
    Model : 15fq2045nt
    Part no : 2N2N8EA
    Serial : 5CD048C6CS
    try 087FD from post #5...
    https://www.badcaps.net/forum/troubl...ighlight=087FD
    • peste
      • Dec 2016
      • 13641
      • ROMANIA
      Model : 15fq2045nt
      Part no : 2N2N8EA
      Serial : 5CD048C6CS
      • Code7
        • Dec 2020
        • 8
        • Turkey
        Originally posted by peste
        The computer was giving a bios failure. But when I tried to do a recovery via USB, the recovery did not start. I tried all the bios on HP website one by one with CH41a. Right now the computer shuts itself off after 3 seconds after turning on. Then it turns on again and turns off again. It's in a loop like this right now.
        I thought if you could look at the bios file you might be able to solve the problem.
        Thank you for your help.​
        • peste
          • Dec 2016
          • 13641
          • ROMANIA
          did you try the bios from the post above?
          • Code7
            • Dec 2020
            • 8
            • Turkey
            Yes. So I downloaded and extracted the bios from the HP site. I've tried all 3 bios you mentioned, but I'll try bios 087FD again, thanks.
            • spoti hakai
              HP 15t-dh100 BIOS recovery help needed
              by spoti hakai
              Hi, thank you for taking time to read this.
              I need help with EC firmware files extraction.
              OMEN Laptop - 15t-dh100 CTO
              Product ID: for more specific accurate search
              8VM74AV
              Can you kindly mention files which should be flashed in 16 MB bios chip? and files which should be flashed in 1 mb chips.
              Bios version: F.44 bricked my laptop.
              F.38 or F.39 were last working files.
              5 capslock long blinks 3 short.
              First, when bios updated started from windows update, it broke the laptop. Second, when i tried Win +V key,...
              11-13-2024, 11:21 AM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              Ack
              Ack
              01-30-2025, 04:26 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • sssssssssssssss
              Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
              by sssssssssssssss
              I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
              Symptoms:
              • Laptop powers on but no display at all (completely black screen)
              • Caps Lock blinks twice with a pause, then repeats continuously
              • F12 LED stays on permanently
              • No POST, no boot sequence, nothing on screen
              Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
              What I've tried:
              • Hardware reset (battery removal, power
              09-04-2025, 06:45 AM
            • ZixuTech
              Turns on and shuts off NUC8I7HNK4 needed a BIOS
              by ZixuTech
              Seems like we are dealing with a case of a corrupted BIOS after Intel Driver software attempted to flash the bios (haven't seen that before). The customer reported seeing a BIOS message while the screen was flickering during the Intel Display Driver installation. This was while the BIOS WRITE lock jumper was in place. Resulting in Loop restarting.
              Afterwards, the customer attempted flashing BIOS via USB stick, resulting now in turning and immediately shutting down unit NUC8I7HNK4.
              Under the thermal cam, I can see that the CPU is initiating a heat signature for a second...
              08-13-2023, 08:55 PM
