BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
  • Fr33man
    • Sep 2024
    • 4
    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
    *Novo button power on
    *Disconnected internal battery & Cmos battery, pressed power button for 60 seconds
    *Removed & reseated SSD and RAM Sticks (cleaned), pressed power button for 60 seconds
    None of these have fixed the semi-bricked Bios, and so requesting the proper Bios file from this forum seems to be my last, best hope. Here's my specifications and the old bios is attached below,
    Model Name: IdeaPad 3-14ALC6
    Machine Type: 82KT
    CPU: Ryzen 5700U
    Serial Number: PF4CD0SF
    Machine Model: 82KT00YSAU
    Mother Board: BDPLANAR MBL82KTWINR75700UUMA_4G RPMC (Part No 5B21B85211)
    Thanks in advance, any help or information will be much appreciated...
    • 22156
    Do you have a bios programmer ?
    • Fr33man
      • Sep 2024
      • 4
      No, I've checked out some YouTube videos on how to program bios chips with a CH341A but I've basically been running with the assumption that this won't be necessary with a semi-bricked bios? Is this a false assumption or can a USM flash drive with the proper Bios file do the job here?
      • ricky arana
        • Apr 2025
        • philiphines
        [QUOTE=Fr33man;n3467135]Hello everyone,
        Machine Type: 82KT
        CPU: Ryzen 5700U
        TR THIS 1
        • peste
          • Dec 2016
          • 13793
          • ROMANIA
          [QUOTE=ricky arana;n3735122]
          Machine Type: 82KT
          CPU: Ryzen 5700U
          TR THIS 1
          you have everything you need at post #52...
          https://www.badcaps.net/forum/troubl...bios-plz/page3
          • pcwhiz24
            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
            by pcwhiz24
            Model: Lenovo IdeaPad 3 14ADA05 81W0
            S/N: PF2BZS7D
            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
            I already have a CH341A programmer...
            04-07-2025, 07:10 PM
          • carabas20
            BIOS bin file for Lenovo Ideapad 3 17ADA6 + 3 15ADA6
            by carabas20
            Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
            I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
            If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios...
            06-01-2023, 01:19 PM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
