Need bios dump for toshiba m305d
  • lezsimply
    The Wanderer
    • 659
    • Philippines
    Hello again. I need bios dump for Toshiba Satellite M305D-S4840. Laptop turns on but no display. check on external also no outputs. Hope someone has Thanks
  • lezsimply
    The Wanderer
    • 659
    • Philippines
    Re: Need bios dump for toshiba m305d
    anyone please?
    Motherboard code: DA0BU2MB8F0 Rev F
    • kimrocco
      • Jan 2014
      • 56
      • F2
      Assalamo Alaykum
      • lezsimply
        The Wanderer
        • 659
        • Philippines
        Thanks man, I will try this one
        • lezsimply
          The Wanderer
          • 659
          • Philippines
          Thank you kimrocco! it worked man
          I downloaded bios from website but it didn't work. I notice both file is almost the same but the one from toshiba has code "this will not work on dos mode" embedded, your's don't have. anyway thanks again cheers man
          • lezsimply
            The Wanderer
            • 659
            • Philippines
            Celebrated to soon. another issue arose, it does not post when hard drive is inserted. Without hard drive, I can use boot cds with no problems. what could be at fault. thanks
            • atsio
              • Oct 2013
              • 819
              • Greece
              Have you updated to the bios from the site?
              • lezsimply
                The Wanderer
                • 659
                • Philippines
                I used kimrocco's file to flash bios. Version of the bios is 2.60, compared to website I think its the latest.
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  I should flash the site bios and then proceed checking if I still have the same fault.
                  • lezsimply
                    The Wanderer
                    • 659
                    • Philippines
                    The owner of this laptop told me he dumped the adapter because its no longer working. I have searched the net and found that this unit uses a 90 watts 4.74A charger. I've got a universal here with the same value.
                    Here's the weird problem, if I use the 90 watts adapter, laptop does not detect the hard drive and the temps are much higher. I then used a 65 watts 3.42a adapter, hard drive gets detected and boots to windows. temps are lower. Now I need to know is there any effect if I use a 65 watt charger with 3.42amps. Or should I stick to the 90 watts one? Thanks!
                    • dj_ricoh
                      • 2073
                      i see you got no choice no?
                      • teknikpc
                        technical
                        • Dec 2016
                        • 63
                        • Türkiye
                        thanks
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • DProf.
                          TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                          by DProf.
                          High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                          Toshiba Dynabook T55/AB, PT55ABP-BJA2
                          MODEL NAME. Satellite L50-D series
                          P[ART NO PS57MN-00600R
                          Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                          09-26-2024, 04:30 AM
