Samsung NP300E5C bios dump needed
  • tomodachi
    • Apr 2012
    • 602
    • Turkey
    I m looking for a BIOS dump file for NP300E5C,
    thanks in advance
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Samsung NP300E5C bios dump needed
    Here
    • tomodachi
      • Apr 2012
      • 602
      • Turkey
      you guys are great ! thank you so much
      • kukasIII
        • Aug 2012
        • 11
        • lisboa
        Originally posted by cyberhack
        Here
        thanks i will test, my machine have that famous bios brick from this machines.
        stuck in bios logo loop.
        • kukasIII
          • Aug 2012
          • 11
          • lisboa
          update ----
          this bios is for np300e5x and not for np300e5c, there are some difference, missing secure boot. i will post the correct one.
          the machine still work and post with this one, but i prefer to load the correct one.
          Marca -samsung
          Modelo -NP300E5C
          Board -Scala3-15/17CRV
          Bios -P03RAQ
          https://www.badcaps.net/forum/attach...1&d=1405354294
          • iskenderus
            • Sep 2014
            • turkey
            thank you so much for bios file
            • zkirac
              • 5
              • turkey
              Here
              Thank you so much its worked well
              • saifi
                • Feb 2015
                • 4
                • india
                thank you very much very helpful
                • Leonidas87
                  • Feb 2015
                  How do we install/update the bios using the file provided?
                  I would like to do the bios update using a USB stick as I can not boot into windows.
                  Any help would be greatly appreciated.
                  • Leonidas87
                    • Feb 2015
                    My np300e5c will not recognize my hard drive and I tested the drive in another computer and it is good. The hard drive is not detected by the laptop properly and i think this may be the solution.
                    • djsly08
                      F.O.F
                      • Mar 2015
                      Originally posted by kukasIII
                      update ----
                      Marca -samsung
                      Modelo -NP300E5C
                      Bios -P03RAQ
                      How to flash?? anyone???
                      FatherOf~5ive
                      • mahfooz
                        • Jul 2014
                        • 8
                        • india
                        thanks
                        • serenatci
                          • Apr 2015
                          • Turkey
                          Here
                          thank you very much
                          • zenithmx
                            • Sep 2015
                            • jersey
                            thx dud!
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              hey mate , welcome to the forum , don't forget to real our rules for the best of the forum.
                              About flashing , you will require a Flasher , for EX MINIPRO TL866CS
                              with this device , you simple need to remove the rom file of your board , and insert it on this device , further than you must get rom files to update your bios .
                              usually to find rom files , or you can chek it here or online on google , or you can get them at the regular laptop brand , toshiba , hp etc etc , but usually they are more hard to use , since they need to be cut , etc etc .
                              Well but stick around , and you'll see how things work around here.
                              best of luck
                              • ledro
                                • Aug 2012
                                • 44
                                • romania
                                thank you !
                                • zaidap
                                  • Nov 2015
                                  • Argentina
                                  Hi...
                                  Thank you very much very helpful
                                  I program the bios with this dump. And work finee...
                                  • Alienvalien
                                    • Jan 2016
                                    Here
                                    i used it my self, 100% workig
                                    • snegurochka
                                      10q! Burn it and work like a charm!
                                      10x again!
                                      JJ
                                      • canali
                                        • Oct 2014
                                        • 192
                                        • turkey
                                        thank you !
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
