need the bios file hp CQ42
  • Rivaldo Martins
    • Feb 2014
    • 39
    • Brasil
    I need the file bios compaq notebook hp Presario CQ42 plate mae DAOAX3MB6C2 REV: C
  • sorinac
    • Jul 2013
    • 123
    • Romania
    Re: need the bios file hp CQ42
    here you go
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 350
      • India
      I need CQ42 451tu main bios 4mb &Ec bios 512 kb.
      problem was screen with light no image caps &num lock working.
      After flasing main bios disply comes boots fine shuts down after 1/2hr.
      while starting error massage ME FE UPDATE FALIOUR than boots
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 350
        • India
        no one has this bios
        • nazrul145
          • Jan 2014
          • 339
          • BD
          Try it
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 350
            • India
            Najrul 145 thanks for bios today i tested it.Display comes for 1time after that no image only screen backlitght on ,caps num lock working fine .any idea .or do i need to flash ec bios 512 kb . thanks
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              Originally posted by ravi_1617
              Najrul 145 thanks for bios today i tested it.Display comes for 1time after that no image only screen back light on ,caps num lock working fine .any idea .or do i need to flash ec bios 512 kb . thanks
              I've got experience on cq42-207tu (quanta ax3 Wimbledon) last week. the case seems similar with your issue, caps-lock and num-lock working but no image on the screen (led 14").but if i test with LED 10" back light come out. then when i check CN2 pin1,2,3 i've got 1.6v. should be 3.3v. trace it back to Q1 mosfet. on pin3=3.6v pin2=3.9v pin1=1.6v check on R10 its ok 330k.
              then try replace ao3404 (if test not shorted, q2,q3,q4 can't test cause covered flex) voila it's worked, I've got image on the screen.
              may be you could check circuit around connector too
              • balattc
                • Feb 2015
                • 153
                • india
                compaq presario cq42 -228tu
                board id : DAOAX3MB6c2
                • coolguy.1595
                  • Oct 2015
                  • india
                  thanks brother
                  • kiwil baraa beree
                    • Feb 2017
                    • 5
                    • indonesia
                    thanks you
                    • babaji
                      • Oct 2015
                      • INDIA
                      friends i need da0ax3mb6c1 1 mb bios.. plz help
                      • larrydc
                        • Apr 2014
                        • 13
                        • venezuela
                        thak you men
                        • dharmvir
                          • May 2016
                          • 4
                          • india
                          • syml taufiq
                            • Jun 2015
                            • 14
                            • indonesia
                            thanks its worked
                            • technician37
                              • Aug 2018
                              • 30
                              • philippines
                              I need bios CQ42-254TU
                              DA0AX1MB6H1 REV: H
                              thanks
                                • 22312
                                DA0AX1MB6H1 REV: H
                                thanks
                                Post your bios backup here .
                                • bhcomputadores
                                  • Jun 2017
                                  • 25
                                  • Brazil
                                  thanks brother
                                  • ravenmx
                                    • May 2018
                                    • 184
                                    • puebla
                                    thanks you it works
                                    • ravenmx
                                      • May 2018
                                      • 184
                                      • puebla
                                      Originally posted by sorinac
                                      here you go
                                      thanks
                                      • radaxs34
                                        • Feb 2020
                                        • 31
                                        • PHILIPPINES
                                        thank you it work. I change the Q1
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • maanee11
                                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                          by maanee11
                                          Hello Everyone,
                                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                          In the website, you can only see specs etc.
                                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                          11-08-2025, 04:08 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
