Mecer CA14DO1 Wizard 2.0
  • clemence
    • Jun 2013
    • 22
    • zimbabwe
    hello engineers i got this Mecer laptop with bios password can anyone help please
    model Y116A REV 7.0
    ON THE COVER MODEL IS CA14D01 WIZZARD 2
    I CANT SEE SERIAL NUMBER
    i have attached bin file with password
  • hoaca388
    Badcaps
    • Jan 2022
    • 12272
    model Y116A REV 7.0
    Here
    • clemence
      • Jun 2013
      • 22
      • zimbabwe
      Thank you so much Hoaca388 worked 100 percent really appreciate you and God bless.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • howardc64
        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
        by howardc64
        TV was fixed just after removing Samsung's rear snap cover.
        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
        Maybe PSU->backlight connector didn't have a good contact?...
        07-23-2025, 12:34 AM
      • johnbeton
        Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
        by johnbeton
        I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
        Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
        This is what I measure so far:
        Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
        PPBUS_G3H = 0,79v
        PPBUS_HS_CPU = 0,79v
        PPBUS_HS_OTH5V = 0,79v
        PPBUS_HS_OTH3V3...
        05-21-2024, 02:06 PM
      • Grunder
        Mecer lobo 1200 /VR-1200BKS Not switching on
        by Grunder
        Hello guys,
        I'm a TV tech and a friend has asked me to look at his Mecer inverter. I haven't connected a battery but plugged it in to the mains and it does run a lamp. The lcd screen is not illuminating. My friend says he mistakenly connected the battery reverse polarity but the Mecer site says it has reverse polarity protection and that I should check the fuses. The fuses check out ok and there is no sign of damage to most of the component's I could check with my meter. I had removed the transformer and heatsinks to check print underneath. Where do I start? Thanks, Mike...
        03-21-2024, 08:59 AM
      • Kodza
        Mecer SF40IL6 need clean me
        by Kodza
        Hi guys I have Mecer Laptop Model SF40IL Main Board SF40IL6. V.1.2 need help to clean the bios. I have tried but no luck.
        Thanks...
        07-11-2025, 09:43 AM
