Lenavo z51-70 can any one remove AMD graphic From Dump
  • kusal
    • Jul 2021
    • 28
    • Sri Lanka
    removed GPU bcz of short Lenavo z51-70 now no display can any one mod this bios to only uma enabled
    • 21467
    Model number "Lenavo z51-70" added to thread title. Read the rules,post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • kitor
      HP Pro Mini 400 G9 - Led code 3/6 Processor does not support an enabled feature / disable AMT in dump?
      by kitor
      Hey,
      I got HP Pro Mini 400 G9 waiting for a long time for a CPU. Bought I3-12100T which is on supported list just to receive code 3,6 which says "Processor does not support an enabled feature".
      After research I found this is most likely due to all the management stuff being enabled in BIOS (it has vPRO essentials I5 sticker so that is very likely) where 12100T definitely does not support it.
      Unfortunately I wasn't able to find any friend who would have and lend me their CPU to fix that... so the question is, can this be changed at bios dump level?
      I attached...
      02-03-2025, 11:09 AM
    • GeryMix
      Microsoft Surface Pro 4 (1724) SEMM remove from BIOS/UEFI dump
      by GeryMix
      Hello everyone!
      I have a surface pro 4 (1724) with corporate management set up (in this case, I understand it's called SEMM). In the operating system installer (Pro version), after connecting to Wi-Fi, it asks me to enter the company system. If I don't sign in, it won't let me continue (similar to enterprise enrollment on chromebooks). This can be avoided if I install the Home version instead of Pro, and then upgrade to the pro version, but this is not very elegant. I would like the machine to be as it should be in factory condition. That's why I would like someone to remove this restriction...
      04-29-2024, 06:39 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • mohammed mohan
      Remove dump password E89382 HSB j mv-4 94v-0
      by mohammed mohan
      Hello
      Can you help me remove the dump password
      the device name- Getac
      model - S410
      09-12-2022, 01:50 AM
