Asus UM425Q bios dump need
  • ledro
    • Aug 2012
    • 52
    • romania
    hello,
    i need bios for :
    Asus UM425Q
    sn: N3N0LP00J84009F
    MB: UX425QA REV3.1 NB2563_PCB_MB_V5
    with old bios only black screen and keep restarting
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Originally posted by ledro
    hello,
    i need bios for :
    Asus UM425Q
    sn: N3N0LP00J84009F
    please try and give feedback
    • ledro
      • Aug 2012
      • 52
      • romania
      i tried, black screen and it restarts every 15 second
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        if this one still doesn't work and still same issue maybe you have a different issue then.
        • ledro
          • Aug 2012
          • 52
          • romania
          not working, probably the on-board memory is defective.
          thank you anyway for your help
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
