HP 15s-GR0010AU - LA-H32AP REV 1.0 BIOS Request
  • saisoni20
    • Feb 2022
    • 111
    Hi guys i've got HP_15s-GR0010AU ( AMD Processor )
    Board number - LA-H32AP REV 1.0
    S/N - CND04994P5
    I have no display on LCD or external Display.
    Someone can help me with new bios.
    Backup attached​
  • fauzanmint
    • Jun 2018
    • 77
    • Indonesia
    try this, update your dmi manually
      • 21058
      DMI 61000 - 6203F .Copy/paste with a hex editor at same offsets in old/new bios
      • saisoni20
        • Feb 2022
        • 111
        worked.
        Thank you so much.
        • saisoni20
          • Feb 2022
          • 111
          After some days it become dead again.
          It's posting but no display now. BIOS got corrupted again.
          Any clue what can cause this issue?
          • fauzanmint
            • Jun 2018
            • 77
            • Indonesia
            Install the battery while the laptop is off. Check on bios pins for small voltages and they are usually unstable up and down. Find out the problem
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • David Gee
              Bios Request HP 17-CN0023DX
              by David Gee
              I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
              I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
              05-03-2025, 09:58 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
