Bios Request HP 17-CN0023DX
  • David Gee
    • Jan 2025
    I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
    I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides WinFlash.exe without a valid BIOS capsule or recovery image.
    The laptop will enter Crisis Recovery Mode using Windows+V + Power (the blink pattern stops), but does not find a valid BIOS image on the USB, which suggests the BIOS file is missing.
    Can you please provide me with the correct BIOS recovery image file (.BIN or .FD) for this model, suitable for Crisis Recovery via USB? This would allow me to complete the recovery process and restore functionality.
    Thank you for your help!
    • 21981
    Post the laptop serial number
    • hoaca388
      Badcaps
      • Jan 2022
      • 12340
      And backup bios file even if it is corrupted.
      • SGVsbG8sIHdvcmxkIQ
        Issue wtih [crisis] BIOS recovery
        by SGVsbG8sIHdvcmxkIQ
        BIOS update bricked my laptop - after restart the was a prompt to Proceed with ROM flash or Abort. None of 2 options worked - upon restart the same prompt shown.
        I downloaded [BIOS update].exe file from Lenovo Support > extracted [firmware descriptor].fd file > renamed it to [correct crisis file name].bin.
        With crisis file on USB drive the Proceed with ROM option launches recovery - after displaying the current and the new BIOS version, the process terminated immediately with validation error:
        Not allow flash. Boot Guard version verification...
        04-28-2024, 03:43 PM
      • pcwhiz24
        Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
        by pcwhiz24
        Model: Lenovo IdeaPad 3 14ADA05 81W0
        S/N: PF2BZS7D
        I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
        I already have a CH341A programmer...
        04-07-2025, 07:10 PM
      • Focus2005
        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
        by Focus2005
        Hello everyone.
        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
        05-01-2025, 05:41 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • The_Memory_Guy
        Dell T7820 stuck in Bios Recovery Mode
        by The_Memory_Guy
        HI,
        I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
        What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
        All of them say to download the latest bios from the dell website which is a .exe file. I have done that
        https://www.dell.com/support/product...BUT090/drivers
        Some...
        07-07-2025, 06:52 AM
