Bios received from local technician extracted from chip and as per the inspection that all is working fine except the display. no GPU damaged no main board issue, no keyboard issue, no fan/battery issues. so shared the details here as received.
					Legion 5 15ARH7H bios request
 Hello everyone !
 Please need bios dump file for lenovo legion 5 15ARH7H NM-E471 REV2.0 mine was corrupted so i can't post backup .
 Thanks!Comment
 Every donation made will go towards server fees and maintenance costs.Comment
 15ARH7H, NM-E471 r 2.0, SN:PF3TSKZR, MTM 82RD0063
 Hey, i've been dealing with a 15ARH7H. Originally came with a no display, now with a bios from this thread.
 https://www.badcaps.net/forum/troubl...h-bios-request
 The Laptop crashes/reboots early on OS boot, but it seems to run memory test w/o issues.
 Please provide me with a bios for this SN, not entirely sure if it would cause it to crash.
 Thanks!Attached FilesComment
 I have the exact same issue. The laptop constantly reboots if running from the nvme, but works fine when running OS from a usb. I did not think it is a bios but if someone could take a look it would be greatly appreciated.15ARH7H, NM-E471 r 2.0, SN:PF3TSKZR, MTM 82RD0063
 Thanks!
 Legion 5 Pro 16ARH7H
 SN: PF3T7DHJ
 Board: NM-E471 REV:2.0Attached FilesComment
 you have everything you need at post #11....
 SN: PF3T7DHJ
 https://www.badcaps.net/forum/troubl...mp#post3650952Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
							Channel: BIOS Requests ONLY!
			by WahazHello,
 I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
			My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
			by macabookHello everyone,
 07-24-2025, 02:17 PM
- Loading...
