i have hp probook 640 g4 stucks hp endpoint security controller
  • testinglaptops
    • Oct 2022
    • 85
    • United Arab Emirates
    Originally posted by hoaca388
    Open the bios file with UEFI Tool. Select VSS2 store ---> Extract as is ....
    Open VSS2 store by HxD editor
    Choose as shown.
    As a final step, we just need to copy this VSS2 store block to the old place through the HxD editor.
    THANK YOU hoaca388 worked for me. I was searching for this solution from long time.
    • harounHD
      • Feb 2017
      • 50
      • Algérie
      Greetings everyone i have an hp 640 g4 laptop with security device problem message after reprogramming the bios file , this is the main and ec file that i used
      • peste
        • Dec 2016
        • 13661
        • ROMANIA
        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
        post S/N, full name and model, motherboard model, product number,etc.
        • harounHD
          • Feb 2017
          • 50
          • Algérie
          Noted
          • harounHD
            • Feb 2017
            • 50
            • Algérie
            sn: 5CG9249YDB PROD ID 5SA02US#ABA
            • harounHD
              • Feb 2017
              • 50
              • Algérie
              #26
              I tried that method but still same issue does not turn on, it turns on only with me programming those two files together but keeps giving that message
                • 21998
                Clean the ME firmware
                • harounHD
                  • Feb 2017
                  • 50
                  • Algérie
                  #28
                  I did
                  • harounHD
                    • Feb 2017
                    • 50
                    • Algérie
                    #29
                    I think i did it wrong or something, can you do a clear me for this main bios
                    • djblack
                      • Jan 2015
                      • pekanbaru
                      #30
                      "As a final step, we just need to copy this VSS2 store block to the old place through the HxD editor."
                      how to put back edited vss2 to main bios ??
                      • lapfix
                        • Mar 2020
                        • 2765
                        • my workshop
                        #31
                        Take a look
                        https://www.badcaps.net/forum/troubl...security-error
                        • fede77
                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                          by fede77
                          Notebook HP ProBook 450 G8
                          ProdID 2K8L1LT#AC8
                          Mother: DAX8QAMB8D0 REV D
                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                          03-10-2025, 07:12 AM
                        • kolebbk
                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                          by kolebbk
                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                          HP Endpoint Security Controller problem
                          there is a problem with the hp endpoint security controller on the unit
                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                          09-04-2024, 12:44 AM
                        • mego1974
                          HP Probook x360 435 G7 Endpoint Security Controller
                          by mego1974
                          Hello
                          i need help
                          I have a laptop HP Probook x360 435 G7 with bios password
                          I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                          I have read the both bios chips and i have posted a picture with the chips pozition.
                          Can anybody help me with intruction or look on the dump if something is wrong ?
                          Thanks in advance!!
                          Edit
                          Serial 5CG03947C4...
                          12-17-2023, 01:57 PM
                        • spider300
                          HP ProBook 430 G8 hp endpoint security controller problem
                          by spider300
                          please Help Me ... ProBook 430 G8
                          HP EndPoint Security Controller Problem...
                          07-11-2023, 08:40 AM
                        • DonZott
                          HP ProBook 650 G8 - Endpoint Security Controller Problem
                          by DonZott
                          I have a HP Probook 650 G8 with the error "There is a problem with the HP Endpoint Security Controller on the unit."
                          After searching on the forum I've opened the device to check what IC's were on the motherboard and I found some corrosion on the pins of the EC ROM.
                          So my guess is that the EC got corrupted?
                          After some more searching on the forum I've found some other threads where this issue was brought up after they removed the password, this is not the case here, the laptop did not have any password and I did not modify the...
                          03-30-2023, 04:26 AM
