i have hp probook 640 g4 stucks hp endpoint security controller
  • jmp9155
    • Jul 2024
    • uae
    accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
    any solution for this issue?
    • 20299
    Post your backups and laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • Danmoh
      • Sep 2021
      • 53
      • Kenya
      HP Probook 640 G4 Hp Endpoint Controller Error
      Laptop is working well though has this error
      Serial Number 5CG8507244
      Attached are the two bios bins.Kindly remove the error for me.Thank you​
      • hoaca388
        Badcaps
        • Jan 2022
        • 11160
        • Viet Nam
        Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
        • Danmoh
          • Sep 2021
          • 53
          • Kenya
          Thanks alot.Working perfectly.
          • Echoo
            • Apr 2018
            • 77
            • Budapest
            I have the same error message: Endpoint security controller... Can anyone help? How can I fix it so I don't have to ask someone all the time?
            HP Probook 640 G4
            5CG9090QQC
            • hoaca388
              Badcaps
              • Jan 2022
              • 11160
              • Viet Nam
              HP Probook 640 G4
              5CG9090QQC
              • Echoo
                • Apr 2018
                • 77
                • Budapest
                Hello!
                My boss bought 10 such machines from the Netherlands, which are password protected. If they all get this error after RC Unlocker, what can I do?​
                  • 20299
                  Good question,and the fix is relatively easy. Why one of our members can`t make a quick guide about it i don`t know.
                  • Echoo
                    • Apr 2018
                    • 77
                    • Budapest
                    Unfortunately, I'm just a simple mechanic who does things, but precisely because of the variety of tasks, I'm not a professional in any of them.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11160
                      • Viet Nam
                      Hello!
                      Open the bios file with UEFI Tool. Click image for larger version
ID:	3310856 Select VSS2 store ---> Extract as is ....
Name:	2024-07-17 18_07_26-tôi có hp probook 640 g4 bị kẹt bộ điều khiển bảo mật điểm cuối hp - Badcaps.png
                      Open VSS2 store by HxD editor
                      Choose as shown. Click image for larger version
ID:	3310858 Click image for larger version
                      As a final step, we just need to copy this VSS2 store block to the old place through the HxD editor.
                      • mosleh
                        Techbalok
                        • Aug 2017
                        • 13
                        • United Arab Emirates
                        Not clear 🤔please explain details.
                        • retrooo
                          • Mar 2017
                          • 88
                          • mexico
                          the process is quite easy to understand just follow the instructions as mentioned
                            • 20299
                            Its still too hard for some. So... https://www.badcaps.net/forum/troubl...security-error
                            • retrooo
                              • Mar 2017
                              • 88
                              • mexico
                              I will make a thread ,listing the steps i did ,in my case ,it was a 840 g8 not listed here,but theres no difference on the process ,i just look for the me tioned string ,some basic serch and replace ,it took less than 10 minutes
                              • YOUCEF4787
                                • May 2014
                                • 14
                                • ALGERIA
                                Serial Number SN 5CG92973HS
                                HP Probook 640 G4.rar
                                  • 20299
                                  If you take time to read the whole thread before posting you`ll see that there are 2 possible fixes that you can try .If you can use a hex editor try the first one,if you can`t try the second. You can at least try........
                                  https://www.badcaps.net/forum/troubl...55#post3310855
                                  https://www.badcaps.net/forum/troubl...post3330356​
                                  • YOUCEF4787
                                    • May 2014
                                    • 14
                                    • ALGERIA
                                    https://www.badcaps.net/forum/troubl...56#post3330356
                                    Thank you it works fine after using hoaca388 method
                                    • Ali_Khan
                                      • Dec 2023
                                      • 12
                                      • Egypt
                                      Open the bios file with UEFI Tool. Select VSS2 store ---> Extract as is ....
                                      Choose as shown.
                                      hi
                                      Just "Extract body" instead of "Extract as is"
                                      • Bios Cracker
                                        • Oct 2024
                                        • 306
                                        • India
                                        They need spoon feeding bro... You have provided the easiest way to clear...Hat's off.
                                        • fede77
                                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                          by fede77
                                          Notebook HP ProBook 450 G8
                                          ProdID 2K8L1LT#AC8
                                          Mother: DAX8QAMB8D0 REV D
                                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                          03-10-2025, 07:12 AM
                                        • kolebbk
                                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                          by kolebbk
                                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                          HP Endpoint Security Controller problem
                                          there is a problem with the hp endpoint security controller on the unit
                                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                          09-04-2024, 12:44 AM
                                        • mego1974
                                          HP Probook x360 435 G7 Endpoint Security Controller
                                          by mego1974
                                          Hello
                                          i need help
                                          I have a laptop HP Probook x360 435 G7 with bios password
                                          I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                                          I have read the both bios chips and i have posted a picture with the chips pozition.
                                          Can anybody help me with intruction or look on the dump if something is wrong ?
                                          Thanks in advance!!
                                          Edit
                                          Serial 5CG03947C4...
                                          12-17-2023, 01:57 PM
                                        • spider300
                                          HP ProBook 430 G8 hp endpoint security controller problem
                                          by spider300
                                          please Help Me ... ProBook 430 G8
                                          HP EndPoint Security Controller Problem...
                                          07-11-2023, 08:40 AM
                                        • DonZott
                                          HP ProBook 650 G8 - Endpoint Security Controller Problem
                                          by DonZott
                                          I have a HP Probook 650 G8 with the error "There is a problem with the HP Endpoint Security Controller on the unit."
                                          After searching on the forum I've opened the device to check what IC's were on the motherboard and I found some corrosion on the pins of the EC ROM.
                                          So my guess is that the EC got corrupted?
                                          After some more searching on the forum I've found some other threads where this issue was brought up after they removed the password, this is not the case here, the laptop did not have any password and I did not modify the...
                                          03-30-2023, 04:26 AM
