Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
  • jeewantha
    • Nov 2016
    • 88
    • Sri Lanka
    Dell Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
    I already write 2 bios files. For both files it is not on.
    Only light up top cover LED..
    Machine Model : Dell Venue 10 Pro 5055
    Service Tag: GWV0G32
    Board Model Number : SILVERTON MB
    14238-1
    WX4XD
    Please help to fix this problem.
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    Serial Number :
    14238-1
    WX4XD
    Please help to fix this problem.​
    nice serial number, is invisible ...
    • jeewantha
      • Nov 2016
      • 88
      • Sri Lanka
      Sorry. I can't find it. That is why I post it blank & attached some images.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12396
        When you request DELL bios help, you must post a backup copy of the bios and service tag number.
        • jeewantha
          • Nov 2016
          • 88
          • Sri Lanka
          Find it.
          Express Service Code: 36815523950
          I will repost this.
          • jeewantha
            • Nov 2016
            • 88
            • Sri Lanka
            14238-1
            WX4XD
            Last edited by peste; 06-23-2024, 09:54 AM. Reason: merged post..the bios also appeared in the end...
            • hoaca388
              Badcaps
              • Jan 2022
              • 12396
              Find it.
              I will repost this.
              Review the article in #4, there are 2 requirements you must meet (currently you can only satisfy 1 of them).
              • minhdigital
                • Nov 2022
                • 765
                • Vietnam
                14238-1
                WX4XD
                The bios also appeared in the end..., take a long time for it, send to you, try !!!
                • jeewantha
                  • Nov 2016
                  • 88
                  • Sri Lanka
                  File is working.
                  Thank you very much
                  • tony0103
                    • Oct 2024
                    • 3
                    • Bolivia
                    Good evening friend, excuse me, how can I introduce this file to my tablet to update the bios please since it keeps restarting, I hope you can help me please and thank you very much in advance.
                    • peste
                      • Dec 2016
                      • 13718
                      • ROMANIA
                      you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                      • andrew25
                        • Feb 2016
                        • 224
                        • Malawi
                        great... worked okay
                        • RetroComputingGrotto
                          New Toy UNI-T UTi260B - What Settings?
                          by RetroComputingGrotto
                          I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                          After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                          I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                          09-02-2025, 08:36 AM
                        • shouri
                          Dell latitude e5490 auto restart
                          by shouri
                          Hi guys, can someone help me?
                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                          After a few days test, is seems ok.
                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                          12-10-2024, 09:27 PM
                        • davincemz
                          Dell Venue 10 Pro 5055 silverton mb 14238-1 schematic
                          by davincemz
                          Hello IM looking for Dell Venue 5055 Pro Boardview and schematic
                          04-01-2023, 12:53 AM
                        • pfrcom
                          Asus P8Z68-V/Gen3, after saving UEFI settings, shuts down, doesn't restart
                          by pfrcom
                          I've tried all BIOSes available to download, most recently first release version 0301, using an i3-2100
                          For each try, after externally reprogramming its Winbond 25Q64BV (DIP8) with TL866IIplus
                          Always same outcome - after Save & Exit, board shuts down and doesn't restart
                          If I press onboard Power button, it'll start up then shut down again
                          After jumpering CMOS Clear, it'll start to UEFI settings then repeat same behaviour
                          It's had a new CR2032 fitted
                          Closer examination found a second flash IC, a soldered...
                          07-29-2021, 02:46 AM
                        • fulepost@outlook.com
                          Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                          by fulepost@outlook.com
                          Dear all.
                          I'm a less knowledgable member who would appreciate some guidence.
                          I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                          With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                          When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                          11-09-2025, 07:10 AM
