HP 840 G4 Working bios
  • azad007
    • May 2016
    • 11
    • Bangladesh
    HP840 G4 I7 7TH GEN 6050A2854301-MB-A01 Tested OK !
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
  • zPwN!
    ENOVA NE14I310 XU133t rev 1.3 working BIOS
    by zPwN!
    Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
    Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
    System SKU NE14I310
    BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
    Motherboard XU133T rev 1.3
    Serial Number IPNBI3X240SM2A01095
    Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
    RAM 8.00 GB
    NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
    01-03-2025, 01:03 AM
    by Vesko356
    08-11-2023, 03:27 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • Sparklingx
    CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
    by Sparklingx
    So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
    So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
    now all...
    08-29-2024, 01:53 PM
